$ sudo asl-show-version
OS Kernel : 6.1.0-38-cloud-amd64
Asterisk : 22.4.1+asl3-3.5.5-1.deb12
ASL [app_rpt] : 3.5.5
Installed ASL packages :
Package Version
allmon3 1.6.0-3.deb12
asl3 3.8-1.deb
asl3-asterisk 2:22.4.1+asl3-3.5.5-1.deb12
asl3-asterisk-config 2:22.4.1+asl3-3.5.5-1.deb12
asl3-asterisk-modules 2:22.4.1+asl3-3.5.5-1.deb12
asl3-menu 1.14-1.deb12
asl3-tts 1.0.1-1.deb12
dahdi 1:3.1.0-2
dahdi-dkms 1:3.4.0-7.asl
dahdi-linux 1:3.4.0-7.asl
Inquiry
I have set up a new Node in an Azure VM with the set up as above, folowing the guide from the wiki.
The node is registered with Allstar just fine, node66517, and although it appears on the surface to be OK there are a couple of issues.
Node 66517 shows thats its not reporting any data although I have uncommented the rpt.conf file to allow this. Is there a port thats means to be passing through to the server to alow this?
More imprortantly, when I try and link the node I get this error:
OK:
Unknown node number 66517.
So although its registered, it appears to not know about itself?/
If anyone can give me some guidance Id really appreciate it, thank you.
Javier.
