Im totally new to allstarlink, and I just installed allstarlink v3 on a Raspberry Pi 4b, and i currently have a G1LRO Universal radio controller connected to the Raspberry Pi, and just for now, i have a Quansheng UV-K58 connected to the Universal Radio Controller until i can get a better radio.
I seem to have most of what i can figure out by watching youtube videos and the G1LRO webpage set up correctly from what i can determine, but obviously something is missing, or maybe a few things.
It doesnt help that the Universal Radio Controller instructions arent referring to the Allstarlink v3 software. As far as the Universal Radio Controller goes, ive followed their instructions and upgraded the firmware, and changed the URCâs ID as per the instructions. The simpleUSB-tune instructions on the G1LRO webpage ( Making an AllStarLink Node with the URC/AIOC â G1LRO HOMEPAGE) is different than the v3 allstarlink, (HAMvoip) so im kinda guessing at this point as to the settings.
Im at the point now in the setup where i boot up the Raspberry Pi, and the UV-K58 that is connected to the Universal radio controller keys up as expected, and i have a separate HT which is also tuned to the same frequency that the Quansheng UV-K58 connected to the URC is, which is 446.100mhz, and when the radio keys up, i can hear what i assume is the node transmitting the morse code repeater startup audio. So, the radio connected to the Universal radio controller transmits from the nide when the system starts up, thats good. Whats bad is that if i try to use any DTMF command on my HT, nothing happens. The mide status shows no connections, and one keyed up.
Looking at the Universal Radio Controller instructions, it says to chsnge the simpleUSB-tune menu settings, but since they are for HAMvoip, the instructions arent the same as my v3.
It says to change the following:
Set option I : PTT Mode to âactive lowâ
Set option J: COSFROM to âusbinvertâ
Set option L: CTCSSFROM to ânoâ.
If i go i to the setup menu, and enter into expert configuration menu, and select âEdit simpleusb.conf fileâ, and then i scrill down to what is closest to the URC page instructions, i see
carrierfrom=usbinvert
Ctcssfrom=invert
Invertptt=no
Im assuming these are the same thing as the different version describes in the URC pages instructions.
If i change ctcssfrom=usbinvert to ctcssfrom=no, and reboot, everything boots as normal, and the radio then does its RF TX thing, but, the TX either does not stop, or, it keys up over and over and over and does not stop, and i can see on the node info admin webpage for my node that it keyed up 17 times before i finally shut off the radio and then changed the ctcssfrom back to âusbinvertâ.
Im not even sure if this should be set as simplex, as hotspot, or repeater, full or half duplex, lol.
So, im not sure why its acting like this, or why if i enter in a DTMF code like 70* on my HT radio, nothing happens. I can see the Quansheng that is connected to the URC receiving my HTâs TX, but the Quansheng doesnt seem to be triggering anything on the URC that i can see, so i dont know if anything is actually getting through to the node or not. I hope all of this is making sense. Im a total newbie to Allstarlink, and im not a linux guru by any means, i barely muddle by.
Im hoping that someone here can guide me through getting this up and running, and also how to properly test it. Im hoping that im even correctly understanding how to use this system by what ive been reading lol. Thanks for your patience with me in advance.
