New error in Astrisk CLI after most recent update
I am getting this warning message in the CLI after installing the most recent security updates.
"[2026-11-03 17:07:36.130] WARNING[1333]: app_gps.c:1289 gps_serial_open: Cannot open serial port : No such file or directory"
Any idea of what I should disable to make this stop? It is just a continuous stream of this warning in the CLI
Well I fixed it but I'm not sure why or how it was turned on. In modules.conf I had to set the app_gps.so ; GPS Interface
to noload so noload =app_gps.so ; GPS Interface
I don't know how it got turned on or if it should be set to load and something else is going on but since I do not have a GPS dongle on the pi I would assume it should be set to no load.
After I posted this I realized app_gps SHOULD be set to load because I was using it to report the repeater location to APRS.
There seems to be some issue since I updated on 11-3-2026 that makes the above warning message repeat over and over in the asterisk console.
I checked the gps.conf file and everything is set the correct way in that file - or - at least the same way it has been set for over a year and worked with no issue.
Does anyone have any idea what else to check? With the comport and baudrate left blank it shouldn't be looking for a serial port correct? The other thing I was thinking was that one of the things that updated might have deleted or changed the permissions for one of the linux devices that app_gps uses?
Any help would be appreciated
Clean the password and post your conf so we can see what you have please.
Thanks for the reply here is the conf:
; Configuration for app_gps
[general]
; settings for the GPS device
comport = ; Serial port for GPS receiver (specify this only if using GPS receiver)
baudrate = ; Baud rate for GPS receiver (specify this only if using GPS receiver), default 4800
; settings for the APRS-IS server
; The APRS-IS callsign (including SSID) for APRS. Additional
; information on the callsign/SSID format can be found at
; Connecting to APRS-IS
call = N3EMC-12 ; Change this!
; The computed APRS-IS password for the above callsign. You can
; generate the password at N5DUX APRS Passcode Generator
password = ; Change this!
; The APRS-IS server to report information
; Worldwide: rotate.aprs2.net (this the default server if not specified)
; North America: noam.aprs2.net
; South America: soam.aprs2.net
; Europe/Africa: euro.aprs2.net
; Asia: asia.aprs2.net
; Oceania: aunz.aprs2.net
; Global Hamnet: aprs.hc.r1.ampr.org
server = noam.aprs2.net
; The APRS-IS port on server to send data
port = 14580
; Beacon interval in seconds
; Mobile 60 to 120, infrastructure 1200, fixed base 1800
interval = 1800
; settings for the APRS position report
comment = 927.700 T156.7 -25Mhz, Allstar Node 67341, TGIF TG 67341 ; Text to be displayed for this station
; To include frequency, tone and offset, the comment should use the following format:
; 145.000MHz T146 -060, AllStar Node 1999
icontable = R ; The icon table to use '/' (primary) or '' (alternate). See the below symbol link.
icon = & ; A House (default) Icon to be displayed for station on APRS
; See http://www.aprs.org/symbols.html
; station information
; see http://www.aprs.org/aprsdos-pix/phg.txt for power, height, gain, and dir settings
freq = 927.700 ; Display frequency of station
tone = 156.7 ; CTCSS tone of station (0.0 for none)
power = 6 ; Power level 0 to 9
height = 1 ; Antenna Height in HAAT 0 to 9
gain = 9 ; Antenna Gain 0 to 9
dir = 0 ; Antenna Direction 0 to 9
; station location information
; lat, lon, elev should be populated if you are not using a GPS device.
; Note: when you use a GPS device, these values will be used when
; the GPS cannot lock to a satellite. Set "ehlert = yes" if
; you do not want to use these defaults when using GPS.
lat = 39.320539 ; Fixed latitude in decimal degrees (positive for North, negative for South)
lon = -76.435146 ; Fixed longitude in decimal degrees (positive for East, negative for West)
elev = 16.7 ; Elevation of Antenna in Meters (NOT HAAT)
;ehlert = yes ; Set this to true to disable the use of the default latitude/longitude
; settings are for APRStt (touch tone) mode. APRStt must be enabled in rpt.conf
;ttcomment = ; Text to be displayed associated with this TT station
;ttlat = ; Fixed latitude in decimal degrees - if not specified 'lat' is used for the default
;ttlon = ; Fixed longitude in decimal degrees - if not specified 'lon' is used for the default
;ttelev = ; Elevation of Antenna in Meters (NOT HAAT) - if not specified 'elev' is used for the default
;ttlist = ; Number of touch tone entries to maintain. Default is 10.
;ttoffset = ; TT Offset from main lat/lon value. Default is 10.
;ttsplit = ; yes = center reports around lat/lon origin, no = (default) only use ttoffset
; If you need per-node APRS customizations you can use a template-based
; configuration. The steps are simple.
; 1. in your "rpt.conf" file you would update the per-node configuration
; to look like :
; 1999
; aprstt = 1999 <--- Add this line to "rpt.conf"
; 2. Uncomment and customize the following section in this file with
; the per-node changes.
; Note: the per-node section below starts off with (inherits) all of the
; settings from the "general" section and then adds/updates settings
; with new/updated values.
;1999
;comment = AllStar Node 1999 ; per-node setting
;freq = 432.100 ; per-node-setting
#tryinclude "custom/gps.conf"
Thanks for posting the config, that explains it.
Your comport = line is blank instead of commented out. app_gps reads a blank value as a serial port with an empty name, not as "no GPS", so it tries to open that port and fails. You can see it in the warning: there's nothing between "serial port" and the colon.
This has always happened with a blank comport. Before the recent update, though, app_gps tried once at startup, logged a single warning and gave up, so it was easy to miss. The update added automatic reconnection for serial GPS receivers, so it now retries every 2 seconds, which is the stream you're seeing. Nothing on your system was deleted or had its permissions changed.
To fix it, put a ; in front of both lines so they're commented out rather than blank:
;comport =              ; Serial port for GPS receiver (specify this only if using GPS receiver)
;baudrate =             ; Baud rate for GPS receiver (specify this only if using GPS receiver), default 4800
Then restart Asterisk:
sudo systemctl restart asterisk
Keep app_gps.so set to load in modules.conf. With no GPS receiver, it beacons the fixed lat, lon and elev from gps.conf, and you have all three set, so your APRS reports keep working and the warnings stop.
That was it. Funny thing was, I did comment them out the other day while trouble shooting but I must have been distracted and didn't restart asterisk after commenting them out. When I posted the config I un-commented them after reading (skimming) the docs section about apps_gps and seeing it said to leave both of those sections blank.
Thank you for the help! 73
