New DIY node with issues
I have a new node I built with a 888 and cm108 that is having an issue. If I fresh boot, the transmitter pulses wile booting. Once everything is loaded it continuously transmits. If I go into the simpleusb tuner and press f it works correctly and functions as intended. The flash function works then the radio goes into recieve and works correctly. I can connect to other nodes everything works great, but if I reboot, it does the same thing again.
Any ideas. This is the only thing stopping me from finishing this project.
Seems many have had issues with the sound fob as of late.
Perhaps there is a clue in reading others solutions ?
