Once loaded on the target computer
Login:
repeater
Passsword:
allstarlink
SSH
port: 22
User
repeater has sudo (root) privileges (sudo -s)
If you
are trying to login via ssh you will also want to edit /etc/ssh/sshd_config.
Use vi editor
Edit
/etc/ssh/sshd_config with the following
Change:
Port
xxx ;new port number
Change:
#PermitRootLogin
prohibit-password
To:
PermitRootLogin
yes
There
may have been updates to the operating system and AllStarLink since this image
was built.
Run
the following commands after the first time you boot.
apt-get
update
apt-get
upgrade -y
reboot
Used
copy of apt_rpt *.conf files (at the # prompt run “asl-menu” to setup
your node)
If
using RPi 3 with wifi, then execute wifi-setup at the command line prompt.
[mailto:app_rpt-users-bounces@lists.allstarlink.org] On Behalf Of Gary Bonebrake
Sent: Sunday, December 09, 2018
8:44 AM
To:
Subject: [App_rpt-users] Net
Install Problem
Greetings,
After several years of successful Asterisk repeater
operation using Centos (node 27610), I have decided to move into the 21st
century and update to Debian/Allstar/Asterisk. Sounded like a great project to
attack over the holidays. I dug up an identical HP dc5100 PC, same as current
repeater controller, for the new system. It has one CDROM drive and many USB
ports.
The install .ISO file on the AllstarLink website is
too big for a CD, so I created a bootable thumbdrive and forced my PC to boot
from that. After the install completes and shuts down, I remove the thumbdrive
and restart the PC. It comes up with the repeater prompt, but does not continue
the installation of Asterisk. There exists no “asterisk.sh”.
I would appreciate guidance on how to proceed.
BTW, the user “repeater” has no privileges
and unknown password (“allstarlink” does not work).
Gary
W5BI
