Need programming software for CM200 and CM300 Motorola
Hi Loren!
I was recently able to program some of my old Motorola Maxtrac radios from a fairly new and very fast Windows 10 machine using DOSBox. I found the keys to the castle in KK6JYT’s online blog post. The first key is to set the cycles in DOSBox to 191. The second thing to do is to use a USB programming cable that has a true FTDI chip in it (at least that’s what I used!) It’s slow in reading and writing the codeplug but it does work! I’ve programmed several radios with it now. I would imagine the same setting might work for your CM200 and CM300 radios if their CPS requires DOS.
Thanks to KK6JYT for publishing this info. My old WinXP laptop is about to die.
Here’s the link to his blog post:
https://kk6jyt.com/motorola-radius-gm300-programming/
Hi All,
The CM200 / CM300 / PM400 is a radio released in the mid 2000’s through 2014-2015, the CPS is not and never was DOS based. The last version of CPS that didn’t require a licence key for programming it wideband was R05.16. R05.16 was released in 2012, windows 10 was released in 2015. The current (and last) version of CPS is R05.18 released in July of 2013.
I’m not sure if R05.16 or R05.18 works on windows 10, works good on windows 7 we use it every day.
Cheers,
Jesse
On Sun, Dec 10, 2017 at 1:38 PM, William Higgins [email protected] wrote:
Hi Loren!
[email protected]
Good Morning.
I live in Brazil, and I have little time as a ham radio operator.
This year I received a Motorola Control M216 radio (VHF - 16 channels). It belonged to a friend of mine, a retired taxi driver.
I have an HT, and I’m using this Motorola m216 with a flower pot antenna to connect to other repeaters.
I read your message about programming software, and I would like to ask for help on which programming software is suitable for this Motorola model, as I need to adjust the frequencies of some repeaters in my region.
I saw many versions on the Motorola website, but I don’t know which one is suitable.
Thank you for your help and your time.
Eduardo Peres Ferreira
PU2NQJ
Brazil
+55 11 980737633 (Whatsapp)
[email protected]
I hope I’m in the right spot for this comment/question:
I became the owner of two UHF CM300s and one VHF CM300. I got some help from a tech friend who happened to have legit licensing and EID for the wideband entitlement under R05.18. This allowed me to go wideband for HAM stuff.
So, the radios are basically set up the way I need them, but as a HAM, I wanted to have my own software installation.
I found a company that will sell (as a two-for-one package) legit licensed Motorola software (R05.16 AND R05.18).
The “16” will program the radios wideband or narrowband with no entitlement code needed.
The “18” will only do narrowband and an entitlement is required to do wideband.
Currently, Motorola (apparently) shut off their online “narrowband training” and shut off the online entitlement registration server to allow wideband entitlement.
A few questions:
  • I’ve heard mixed opinions if a radio “touched” by 18 will no longer be able to be programmed using 16. Right or wrong?
  • If 16 won’t work on the radio touched by 18, is there a hack or bit-bash to downgrade the radio to accept 16 after it have been touched by 18?
  • Is there a hack to the now-unsupported software turn off the entitlement requirement in 18?
I know I’m probably pondering the imponderable, but I thought I’d ask……
‘73’
Steve, N9ATO
