You only need 3 wires going into the transmitter. What I am talking about is pre-emphasized vs flat input audio to the radio.
On the Motorola, you may have chose to use flat audio into the radio for TX, however, on the chinese radio, you only have mic audio in, so in the usbradio.conf, you have to set txprelim to no.
On Mon, May 30, 2016 at 9:14 AM, Loren Tedford lorentedford@gmail.com wrote:
ok we are only using filtered audio at the moment we don’t trust the uri to decode our tones or transmit our tones… So that config already looks correct…
So i need PTT to GND and Audio out to the MIC on the RJ45 what about the other wires…
Loren Tedford (KC9ZHV)
Email: lorentedford@gmail.com
http://www.lorentedford.com
http://www.kc9zhv.com
http://forum.kc9zhv.com
http://hub.kc9zhv.com
http://www.newwavesucks.com
http://forum.newwavesucks.com
On Mon, May 30, 2016 at 10:09 AM, Skyler F electricity440@gmail.com wrote:
Ok, first, if you are using flat TX audio on the motorola, you will have to set txprelim and txlimonly to no in the rpt.conf file.
I think the connector might be the same as a kenwood, do kenwood miss work with it, if so, this diagram may help you:
http://radioaficion.com/cms/wp-content/uploads/2015/07/Leixen_VV-898_Microphone_Connector_Pin_Out.jpg
You are going to need to send PTT, GND, and audio out to the mic in on the RJ45 jack
On Mon, May 30, 2016 at 9:05 AM, Loren Tedford lorentedford@gmail.com wrote:
If I am guessing correctly I could probably take the rj45 and make it transmit the audio from the tx side of the URI 16 pin connector however kinda confused which wire needs to go where…
Skyler Fennell
amsatnet.info
KDØWHB
On Mon, May 30, 2016 at 10:04 AM, Loren Tedford lorentedford@gmail.com wrote:
skyler i have a sic 2 meter transmitter at the moment i am limping it along until we get our new transmitter ordered at the moment i have a GM300 which is drifting slightly back and forth but i need the JT270M to take the place of our current transmitter so we can at least put the system in more of a stable operation
On Mon, May 30, 2016 at 10:01 AM, Skyler F electricity440@gmail.com wrote:
So are you using one of the radios as a transmitter and another as a receiver? Which radio are you using for which?
73,
Skyler
On Mon, May 30, 2016 at 6:11 AM, Loren Tedford lorentedford@gmail.com wrote:
Greetings I need pin out info on a jetstream 270m to Motorola 16 pin adapter for the transmitter and receiver the most important thing at moment is transmitter…
If possible diagrams would help me see this a little better… We have the uricables from http://uricables.com/DuplexMotorola.html
Phone: 618-553-0806
Fax: 16185512755
http://kc9zhv.com
Sent from Droid Turbo from Verizon wireless network
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
