Can someone out there give me iax rpt and extension config files please as im think im mess up as im can connected my echolink node but when a user connection it disconnected them as im only can get 1 node connected im open the firewall ports 4570 and 4569 as well
Im have it out side of my qth in a vps it just only let 1 user to connected for some reson
Note: I do not use the var global logic for this.
I have to many private nodes to track and see no use for it. I like exact definition.
But if you use the stock stanza, you need to fill in a global var for node = xxxxx at the top of extentions.conf. Create a new one for a second node of a different variable name and add that to the stanza.
in iaxrpt program
Make sure your user = iaxrpt
“Account Name” becomes node#.
Don’t confuse this with “user”, which is the stanza name.
Anyway, that should clear up where I think many are in error.
