Need help connecting a Baofeng UV-5R with DMK URI-x
Dear List members
Good morning. I need a bit of help in connecting a Baofeng UV-5R with
DMK URIx device. I have googled as much as I practically could, but
still could not decide/confirm as to what should be the approach.
First of all, I came across the pin-out for the baofeng at Miklor site
http://www.miklor.com/COM/UV_Technical.php
I have also seen how DMK suggests any generic radio should be connected
at http://www.dmkeng.com/images/9080-FRS.pdf
And finally, I have found the site that shows how to get the COR out of
baofeng http://alaskareflector.org/zl1nc/UV-COS.html
Now, my expertise in electronics is sub-zero -- I know some very basics
about what component does what, and that's all. So, I have several
questions, and would appreciate if someone with sufficient relevant
experience could please point me to the correct decision.
1. the URI diagram uses several resistors, do I really need them? Or
should I just connect things direct?
2. the main URI diagram shows pin 7 as CTCSS_det and pin 8 as COR_det,
so should I connect the COR from baofeng to pin 8?
3. based on what I can understand from all the links above, I should connect
large stereo body -> D-Sub pin 1
large stereo ring -> D-Sub pin 22
small stereo tip -> D-Sub pin 21
COR (taken from pin 2 of the IC) -> D-Sub pin 8
Is the above correct? Or do you have different experience?
Thanks for your response.
Regards
Shamim
I am also looking to connect a UV-5R to the URI-X but using ONLY the speaker/mike jack and usbradio with DSP detection of audio - the radio will do the CTCSS handling and should only provide audio when CTCSS is met.
Thanks!
Steven Donegan
KK6IVC General Class FCC License
Silver State Car #86
www.sscc.us
To: app_rpt-users@ohnosec.org
Sent: Monday, November 2, 2015 4:45 PM
Subject: [App_rpt-users] Need help connecting a Baofeng UV-5R with DMK URI-x
Dear List members
Now, my expertise in electronics is sub-zero – I know some very basics
about what component does what, and that’s all. So, I have several
Regards
Shamim
Hello all
Further to my previous email, i have come across this link
http://latinovoip.net/baofeng-uv-6-as-an-irlpecholinkallstarlink-2-meter-or-440-mhz-70cm-radio/
This one is using a UV-6R, but i am assuming that the pinout for speaker mic is the same.
Would appreciate if someone could please confirm.
Thanks and regards
Shamim
Thanks!
Steven Donegan
www.sscc.us
Dear List members
large stereo body → D-Sub pin 1
large stereo ring → D-Sub pin 22
small stereo tip → D-Sub pin 21
COR (taken from pin 2 of the IC) → D-Sub pin 8
Regards
Shamim
