The attached pdf documents the procedure used to install the dahdi_dummy on my
AllStar Raspberry Pi Node.
Bill
ASL build dahdi_dummy…pdf (197.1 KB)
From: Brett Friermood via AllStarLink Discussion Groups [email protected]
Sent: Tuesday, April 21, 2020 3:40 PM
To: [email protected]
Subject: [AllStarLink Discussion Groups] [App_rpt-users] Need better instuctions for dahdi_dummy install
Brett_Friermood
April 21
That’s what I just did.
I have a semi-working system on which I’m attempting to install dahdi_dummy. I’ve been working on setting it up for a while, and while the kernel packages were held per the README, “apt upgrade” had been run a number of times.
So, per your prior post regarding needing to have a fresh image, I removed the SD card and re-imaged it. Prior to placing the card back into the Pi and booting, I did a few housekeeping items such as copying my saved configuration files in and changing hostname.
First thing after booting the Pi and logging in, I held the kernel packages with apt-mark. I then installed the required packages per the wiki, which as you know required refreshing the repositories with “apt update”.
Attempting to build using make threw the same error of not having the correct kernel sources.
In Reply To
wllmbecks1
April 21
Brett, It’s been a little while since I ran through this but. I recall that I did perform sudo apt-get update that’s needed to refresh the repository cache. However, do not perform any sudo apt-get upgrade steps until after you have successfully built the dhadi_dummy. Let me know if this doesn’t…
