NanoPi
Hi Guys
I have tried loading ASL_1.01-20180228-armhf-nanopi image onto a NanoPi
Seems to load fine I run the updates etc then the Menu all seems OK but AllStar does not seem to run ?
return email: bob@Fot.com.au
NODE=47324
REGPASS=47324:xxxxx@register.allstarlink.org ; This must be changed to your node number, password
Call sign: VK6Z
Interface type: SimpleUSB/usb_47324 ; SimpleUSB
Echolink Callsign: INVALID
Echolink node: 000000 ASL node used:
Ping test to 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=60.5 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=60.1 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=59.8 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=117 time=60.1 ms
— 8.8.8.8 ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 59.856/60.180/60.579/0.357 ms
Ping test to register.allstarlink.org
PING register.allstarlink.org (67.215.233.178) 56(84) bytes of data.
64 bytes from seal.lambdatel.com (67.215.233.178): icmp_seq=1 ttl=50 time=209 ms
64 bytes from seal.lambdatel.com (67.215.233.178): icmp_seq=2 ttl=50 time=208 ms
64 bytes from seal.lambdatel.com (67.215.233.178): icmp_seq=3 ttl=50 time=208 ms
64 bytes from seal.lambdatel.com (67.215.233.178): icmp_seq=4 ttl=50 time=287 ms
register.allstarlink.org ping statistics —
rtt min/avg/max/mdev = 208.420/228.404/287.132/33.912 ms
Ouput of ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.168.55 netmask 255.255.255.0 broadcast 192.168.168.255
inet6 fe80::6888:f0ff:fe2f:e5b prefixlen 64 scopeid 0x20
ether 6a:88:f0:2f:0e:5b txqueuelen 1000 (Ethernet)
RX packets 2688 bytes 223583 (218.3 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1227 bytes 325560 (317.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 33
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 32 bytes 2608 (2.5 KiB)
TX packets 32 bytes 2608 (2.5 KiB)
Output of lsmod grep dahdi
IAX2 registry
Unable to connect to remote asterisk (does /var/run/asterisk.ctl exist?)
Asterisk version:
Current date and time: 2018-07-23.11:36
updatenodelist service running?
root 657 0.0 0.4 4428 2392 ? Ss 11:14 0:00 /bin/bash /usr/local/bin/rc.updatenodelist &
root 1637 0.0 0.1 3764 548 pts/0 S+ 11:40 0:00 grep updatenodelist
/tmp/rpt_extnodes-temp file
-rw-r–r-- 1 root root 0 Jul 23 11:15 /tmp/rpt_extnodes-temp
/var/lib/asterisk/rpt_extnodes file
-rwx------ 1 root root 141311 Jul 23 11:09 /var/lib/asterisk/rpt_extnodes
####### Begin warnings from messages file
####### Begin warnings from messages.1 file
journalctl –xe
Using username “repeater”.
repeater@repeater’s password:
\ | | __ _ _ __ ___ | _ (_) | \ | | ___ ___
| |/ ` | ’ \ / _ | |_) | | | | |/ _ / _ \
\ | (| | | | | () | __/| | | |\ | __/ (_) |
| _|_,|| ||___/|| || || _|_|_/
Welcome to ARMBIAN 5.41 user-built Debian GNU/Linux 9 (stretch) 4.14.18-sunxi
System load: 0.00 0.02 0.00 Up time: 9 min Local users: 2
Memory usage: 10 % of 493MB IP: 192.168.168.54
CPU temp: 29°C
Usage of /: 10% of 15G
Last login: Mon Jul 23 10:04:18 2018 from 192.168.168.26
repeater@repeater:~$
repeater@repeater:~$ sudo -s
[sudo] password for repeater:
root@repeater:/home/repeater# journalctl -xe
– The start-up result is done.
Jul 23 10:05:21 repeater systemd[1]: dev-dahdi-pseudo.device: Job dev-dahdi-pseu
Jul 23 10:05:21 repeater systemd[1]: Timed out waiting for device dev-dahdi-pseu
– Subject: Unit dev-dahdi-pseudo.device has failed
– Defined-By: systemd
– Support: https://www.debian.org/support
– Unit dev-dahdi-pseudo.device has failed.
– The result is timeout.
Jul 23 10:05:21 repeater systemd[1]: Dependency failed for Asterisk PBX and tele
– Subject: Unit asterisk.service has failed
– Unit asterisk.service has failed.
– The result is dependency.
Jul 23 10:05:21 repeater systemd[1]: asterisk.service: Job asterisk.service/star
Jul 23 10:05:21 repeater sudo[1169]: pam_unix(sudo:session): session closed for
Jul 23 10:06:23 repeater sudo[1370]: repeater : TTY=pts/2 ; PWD=/home/repeater ;
Jul 23 10:06:23 repeater sudo[1370]: pam_unix(sudo:session): session opened for
lines 1316-1338/1338 (END)
Current default time zone: ‘Australia/Perth’
Local time is now: Mon Jul 23 09:35:43 AWST 2018.
Universal Time is now: Mon Jul 23 01:35:43 UTC 2018.
grep: /etc/systemd/network/eth0.network: No such file or directory
/usr/local/sbin/net-setup: line 171: [: missing `]’
mv: cannot stat ‘/tmp/extensions.conf.tmp’: No such file or directory
mv: cannot stat ‘/tmp/echolink.conf.tmp’: No such file or directory
mv: cannot stat ‘/tmp/iax.conf.tmp’: No such file or directory
mv: cannot stat ‘/tmp/modules.conf.tmp’: No such file or directory
mv: cannot stat ‘/tmp/rpt.conf.tmp’: No such file or directory
mv: cannot stat ‘/tmp/savenode.conf.tmp’: No such file or directory
mv: cannot stat ‘/tmp/manager.conf.tmp’: No such file or directory
mv: cannot stat ‘/tmp/usbradio.conf.tmp’: No such file or directory
mv: cannot stat ‘/tmp/simpleusb.conf.tmp’: No such file or directory
mv: cannot stat ‘/tmp/voter.conf.tmp’: No such file or directory
Anyone got any ideas ??
VK6ZGN
Bob** ** Bob@Fot.com.au
Western Australia Mob. 61 (0) 418 902 194
The contents of this e-mail (including any attachments) may be
confidential and privileged. Any unauthorised use of this document
or it’s contents is prohibited. If you have received this e-mail in
error, please notify us immediately and erase this document
E&OE
Bob,
It looks like DKMS did not rebuild DAHDI properly.
Please do as root:
dpkg-reconfigure asl-dahdi-linux-dkms
reboot
Should now be fixed. Check DAHDI is running by:
lsmod | grep dahdi
73, Steve N4IRS
On 07/25/2018 04:38 AM, Bob Good wrote:
Hi Guys
�ASL_1.01-20180228-armhf-nanopi image onto a NanoPi
NODE=47324
Call sign:����� VK6Z
      Interface type:� SimpleUSB/usb_47324� ;
SimpleUSB
Echolink node: 000000� ASL node used:
data.
time=60.5 ms
time=60.1 ms
time=59.8 ms
time=60.1 ms
      --- register.allstarlink.org ping
statistics —
Ouput of ifconfig
      eth0:
flags=4163<UP,BROADCAST,RUNNING,MULTICAST>� mtu 1500
      ������� inet 192.168.168.55� netmask
255.255.255.0� broadcast 192.168.168.255
      ������� inet6 fe80::6888:f0ff:fe2f:e5b�
prefixlen 64� scopeid 0x20
      ������� ether 6a:88:f0:2f:0e:5b� txqueuelen
1000� (Ethernet)
      ������� RX packets 2688� bytes 223583
(218.3 KiB)
      ������� RX errors 0� dropped 0� overruns 0�
frame 0
      ������� TX packets 1227� bytes 325560
(317.9 KiB)
      ������� TX errors 0� dropped 0 overruns 0�
carrier 0� collisions 0
������� device interrupt 33�
      lo: flags=73<UP,LOOPBACK,RUNNING>�
mtu 65536
������� inet 127.0.0.1� netmask 255.0.0.0
      ������� inet6 ::1� prefixlen 128� scopeid
0x10
      ������� loop� txqueuelen 1000� (Local
Loopback)
������� RX packets 32� bytes 2608 (2.5 KiB)
frame 0
������� TX packets 32� bytes 2608 (2.5 KiB)
IAX2 registry
Asterisk version:
      root������ 657� 0.0� 0.4�� 4428� 2392
?������� Ss�� 11:14� �0:00 /bin/bash
      root����� 1637� 0.0� 0.1�� 3764�� 548
pts/0��� S+�� 11:40�� 0:00 grep updatenodelist
      -rw-r--r-- 1 root root 0 Jul 23 11:15
journalctl �xe
_�� _������������������ ____� _�� _�� _
      | \ | | __ _ _ __�� ___ |� _ \(_) | \ | |
___� ___
      |� \| |/ _` | '_ \ / _ \| |_) | | |� \| |/
_ / _ \
      | |\� | (_| | | | | (_) |� __/| | | |\� |�
__/ (_) |
      |_| \_|\__,_|_| |_|\___/|_|�� |_| |_|
_|_|_/
      System load:�� 0.00 0.02 0.00�� Up
time:������ 9 min����������� Local users:�� 2
      Memory usage:� 10 % of 493MB���
IP:����������� 192.168.168.54
CPU temp:����� 29�C
Usage of /:��� 10% of 15G
192.168.168.26
-xe
      -- Subject: Unit dev-dahdi-pseudo.device
has failed
      -- Subject: Unit asterisk.service has
failed
‘Australia/Perth’
      Local time is now:����� Mon Jul 23 09:35:43
AWST 2018.
      Universal Time is now:� Mon Jul 23 01:35:43
UTC 2018.
missing `]’
      mv: cannot stat '/tmp/extensions.conf.tmp':
      mv: cannot stat '/tmp/echolink.conf.tmp':
      mv: cannot stat '/tmp/iax.conf.tmp': No
      mv: cannot stat '/tmp/modules.conf.tmp': No
      mv: cannot stat '/tmp/rpt.conf.tmp': No
      mv: cannot stat '/tmp/savenode.conf.tmp':
      mv: cannot stat '/tmp/manager.conf.tmp': No
      mv: cannot stat '/tmp/usbradio.conf.tmp':
      mv: cannot stat '/tmp/simpleusb.conf.tmp':
      mv: cannot stat '/tmp/voter.conf.tmp': No
VK6ZGN
Bob������������������� Bob@Fot.com.au
      Western Australia������������������������� Mob. 61� (0) 418 902 194
attachments) may be
                  or it's contents is prohibited. If you have
this document
      E&OE
Hi Steve
Thanks that worked…… However now all seems to load and registers OK but SimpleUSB wont loa/run ?
return email: Bob@Fot.com.au
NODE=47324
REGPASS=47324:xxxxxx@register.allstarlink.org ; This must be changed to your node number, password
Call sign: VK6ZGN
64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=77.5 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=70.6 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=84.1 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=117 time=84.4 ms
rtt min/avg/max/mdev = 70.664/79.212/84.453/5.656 ms
64 bytes from seal.lambdatel.com (67.215.233.178): icmp_seq=4 ttl=50 time=208 ms
rtt min/avg/max/mdev = 208.471/208.709/209.006/0.220 ms
Ouput of ifconfig
inet 192.168.168.39 netmask 255.255.255.0 broadcast 192.168.168.255
inet6 fe80::4f:49ff:fe38:5803 prefixlen 64 scopeid 0x20
ether 02:4f:49:38:58:03 txqueuelen 1000 (Ethernet)
RX packets 1641 bytes 149786 (146.2 KiB)
TX packets 1781 bytes 554581 (541.5 KiB)
device interrupt 33
RX packets 16 bytes 1312 (1.2 KiB)
TX packets 16 bytes 1312 (1.2 KiB)
dahdi 200704 28
IAX2 registry
67.215.233.178:4569 Y 47324 58.178.114.94:64301 60 Registered
Asterisk version:
Asterisk GIT Version adaec47 built by root @ odroidxu4 on a armv7l running Linux on 2018-03-07 14:53:41 UTC
Current date and time: 2018-07-26.04:32
root 682 0.0 0.4 4428 2384 ? Ss 04:29 0:00 /bin/bash /usr/local/bin/rc.updatenodelist &
root 1650 0.0 0.1 3764 560 pts/2 S+ 04:35 0:00 grep updatenodelist
-rw-r–r-- 1 root root 0 Jul 26 04:30 /tmp/rpt_extnodes-temp
-rwx------ 1 root root 140551 Jul 26 04:26 /var/lib/asterisk/rpt_extnodes
[Jul 26 04:26:42] WARNING[987] chan_simpleusb.c: Loaded parameters from simpleusb_tune_usb_47324.conf for device usb_47324 .
[Jul 26 04:26:42] WARNING[987] chan_simpleusb.c: Unable to re-open DSP device 1 (usb_47324): No such file or directory
[Jul 26 04:26:42] WARNING[986] chan_simpleusb.c: Unable to re-open DSP device 1 (usb_47324): No such file or directory
And so on forever !!
Bob
VK6ZGN
From: App_rpt-users [mailto:app_rpt-users-bounces@lists.allstarlink.org] On Behalf Of Steve Zingman
Sent: Wednesday, 25 July 2018 17:58
To: Users of Asterisk app_rpt
Subject: Re: [App_rpt-users] NanoPi
Bob,
Please do as root:
reboot
lsmod | grep dahdi
73, Steve N4IRS
Hi Guys
NODE=47324
VK6ZGN
**Bob ** Bob@Fot.com.au
E&OE
[http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
To unsubscribe from this list please visit [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users) and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
This is because OSS is not supported and marked as broken in current Linux distributions. You can either use a kernel that has it compiled in or you can do what I did and use:
ALSA
PulseAudio
osspd (emulates oss through pulse)
I’ll write up some basic instructions for how mine is working… but the net of it it is that without /dev/dsp1 your asl can’t send or receive audio via your sound card (URI)
Maybe I’m talking out of turn, I did not read the entire thread back.
On Jul 26, 2018, at 07:52, Bob Good Bob@Fot.com.au wrote:
Hi Steve
NODE=47324
Call sign: VK6ZGN
Ouput of ifconfig
device interrupt 33
dahdi 200704 28
IAX2 registry
Asterisk version:
Bob
VK6ZGN
Bob,
Please do as root:
reboot
lsmod | grep dahdi
73, Steve N4IRS
Hi Guys
NODE=47324
VK6ZGN
E&OE
JJ is correct. When the kernel was updated the new kernel no longer
supports OSS. While waiting for JJ to publish his work around or for
the dev team to produce a nono OSS channel driver, I’ll post the
info to put the kernel and headers on hold to keep OSS support.
I'll have the info up by tomorrow morning.
Steve N4IRS
ALSA
PulseAudio
thread back.
Sent from the iRoad
      On Jul 26, 2018, at 07:52, Bob Good <Bob@Fot.com.au          >
wrote:
Hi Steve
              return
NODE=47324
              Call
sign: VK6ZGN
              Interface
              Echolink
Callsign: INVALID
              Echolink
              Ping test
to 8.8.8.8
              PING
              64 bytes
              64 bytes
              64 bytes
              64 bytes
              4 packets
              rtt
              Ping test
              64 bytes
              64 bytes
              64 bytes
              64 bytes
ping statistics —
              4 packets
              rtt
              Ouput of
ifconfig
              eth0:
1500
192.168.168.255
0x20
collisions 0
device interrupt 33
              lo:
collisions 0
              Output of
lsmod grep dahdi
              dahdi
200704 28
              IAX2
registry
              Host
State
              67.215.233.178:4569
Registered
              Asterisk
version:
              Asterisk
              Current
              updatenodelist
service running?
              root
              root
grep updatenodelist
file
              -rw-r--r--
file
              -rwx------
              [Jul 26
device usb_47324 .
              [Jul 26
directory
              [Jul 26
directory
              And so on
forever !!
Bob
VK6ZGN
From: App_rpt-users [mailto:app_rpt-users-bounces@lists.allstarlink.org ]
Bob,
            Please do as root:
            reboot
            lsmod | grep dahdi
            73, Steve N4IRS
wrote:
Hi Guys
NODE=47324
VK6ZGN
                                  Western
erase this document
              E&OE
email address and press the “Unsubscribe or edit options
button”
                      You do not need a password to unsubscribe, you can do
it via email confirmation. If you have trouble
unsubscribing, please send a message to the list detailing
the problem.
Hi Steve
Thks for the response !
Where can I download the solution ?
Thks for all your work
Bob
VK6ZGN
ALSA
PulseAudio
thread back.
Sent from the iRoad
wrote:
Hi Steve
              return
NODE=47324
              Call
sign: VK6ZGN
              Interface
              Echolink
Callsign: INVALID
              Echolink
              Ping test
to 8.8.8.8
              PING
              64 bytes
              64 bytes
              64 bytes
              64 bytes
              4 packets
              rtt
              Ping test
              64 bytes
              64 bytes
              64 bytes
              64 bytes
ping statistics —
              4 packets
              rtt
              Ouput of
ifconfig
              eth0:
1500
192.168.168.255
0x20
collisions 0
device interrupt 33
              lo:
collisions 0
              Output of
lsmod grep dahdi
              dahdi
200704 28
              IAX2
registry
              Host
State
              67.215.233.178:4569
Registered
              Asterisk
version:
              Asterisk
              Current
              updatenodelist
service running?
              root
              root
grep updatenodelist
file
              -rw-r--r--
file
              -rwx------
              [Jul 26
device usb_47324 .
              [Jul 26
directory
              [Jul 26
directory
              And so on
forever !!
Bob
VK6ZGN
Bob,
            Please do as root:
            reboot
            lsmod | grep dahdi
            73, Steve N4IRS
wrote:
Hi Guys
NODE=47324
VK6ZGN
                                  Western
erase this document
              E&OE
button”
the problem.
