I am stuck . . .
My Private node is NOT connecting to my Public node:
both are on the same server / same network
testing connection in allmon3:
I execute the connect command - it says it is connected but does not show that they are connected as in previous installations.
OS Kernel : 6.12.47+rpt-rpi-v8
Asterisk : 22.5.2+asl3-3.6.2-1.deb13
ASL [app_rpt] : 3.6.2
You do not need to have different port numbers if you are on the same network/server!
In your extension,conf, do you have your 2 node public and private?
Like this
[radio-secure]
exten => 671040,1,rpt,671040
exten => 1331,1,rpt,1331
kk6rq & n6zcm:
I made the following changes to rpt.conf
671040 = [email protected]:4579/671040,NONE
1331 = [email protected]:4578/1331,NONE
(different of ports now)
I noticed a line in extension.conf:
[radio-secure]
;;exten => ${NODE},1,rpt(${EXTEN}) ←- this was remarked out but there none the less.
2. I tried separately these two scenarios:
a)
[radio-secure]
both a & b had the same result:
when I attempt the connection - the two nodes shows “status - connecting” but never connects.
that is: is shows “status - connecting” in allmon3 for 3 sec. but never connects.
wa3wco: no sir there is no space there - that was just a cut and paste error.
