My node says not regeistered
Good Morning.
My node has been working fine, I disconnected and moved to a new location and now I cannot connect to other nodes. It is connected to the wifi and I get an address with no problem. after leaving it connected for awhile, the server still reports NOT REGISTERED. What can I do to correct this?
Thank you
Ben AB7I
Everything looks ok from this end. Did it start working for you?
No response from AB7I in 20 days. Node 52820 still showing registered. Assuming allis well. Closing Topic.
