My ASL3 after update got problem
OS Kernel : 6.12.75+rpt-rpi-2712
Asterisk : 22.8.2+asl3-3.8.3-1.deb13
ASL [app_rpt] : 3.8.3
Installed ASL packages :
Package Version
allmon3 1.8.1-1.deb13
asl3 3.17-1.deb13
asl3-appliance 2.1.0-2.deb13
asl3-appliance-pi 2.1.0-2.deb13
asl3-asterisk 2:22.8.2+asl3-3.8.3-1.deb13
asl3-asterisk-config 2:22.8.2+asl3-3.8.3-1.deb13
asl3-asterisk-modules 2:22.8.2+asl3-3.8.3-1.deb13
asl3-menu 1.18-1.deb13
asl-apt-repos 2.0-1.deb13
cockpit 337-1
cockpit-bridge 337-1
cockpit-networkmanager 337-1
cockpit-packagekit 337-1
cockpit-sosreport 337-1
cockpit-storaged 337-1
cockpit-system 337-1
cockpit-wifimanager 1.2.0-1.deb13
cockpit-ws 337-1
dahdi 1:3.1.0-2.1
dahdi-dkms 1:3.4.0-11.asl.deb13
dahdi-linux 1:3.4.0-11.asl.deb13
dahdi-source 1:3.4.0-11.asl.deb13
sprkx@68218:~ $
Inquiry
Hi, I need some help with my ASL3 node after the new update, I can only hear the node feedback me just a “TEEETTT” sound like a test tone. Its not a constant tone, just if other person keyed up and talk. I can only hear that. When turn on/restart the node also only hear that “TEEETT', no more the announcement like “ node connected,etc etc”
Last week was just fine. After the update I got into this problem. I tried to re-image back ( 3 times), change different power,USB, re-sit the HAT. I use raspberry pi5 and somewhat like shari pizero HAT called RAPZHAN build by local ham operator in my country - 9M2IBR
To clarify your question, are you saying telemetry tones are not playing, or the sounds files that speak status, or even incoming audio from other nodes?
All of it sir. Anything that node transmitting to my analog radio I only hear “TEEETTTTT” sound. Whether its long or short transmission.
I tried getting help from Ai gemini. It said that my HAT driver is usbfs not usbhid. Tried to unbind from usbfs and to force bind to usbhid but terminal shows I/O error. Check asl-find-sound can found my hat cmedia.
AI advice on ASL using sound devices is almost undoubtedly going to be wrong. You don't need to bind/unbind anything about the audio device. However ASL does take exclusive access of the device so if you setup something that's fiddling with it via ASLA/Pipeaudio or something else you may be blocking it that way. Nothing about the last update changed anything substantive with the USB audio drivers. Are you using SimpleUSB or USBRadio? Does devstr= in the appropriate conf file match the output of asl-find-sound?
I tried both simpleUSB & USBradio. Nothing change. Before I got this problem my setting was USBradio. But after multiple time reimage the sdcard I just set to simpleUSB as it is new installation from raspi imager followed exactly as on manual.
Have you tried updating the RF Module settings (one pic looks like it's a SR105U) ?
At this point I would revert to the backup SD card you should have containing the system that worked last week, to verify your hardware is still working.
Thats my rookie mistake. I didnt do the backup. :downcast_face_with_sweat:
Yes its a SR105U.. I tried but still same.
the ASL3 appliance image makes it quite easy to go from a just installed unconfigured state to a node-added and interface configured state
perhaps start over from scratch? and then use the asl-menu -> "Node Settings" -> "AllStar Node Setup Menu" -> "Add Node" -> "Interface Tune CLI" to test and configure the interface?
Problem founded. My radio on the HAT burned. Thank you for all the help.
