Multi-node...conflicting USB devices
Asterisk : 22.5.2+asl3-3.6.3-1.deb12
ASL [app_rpt] : 3.6.3
Inquiry
I have aRpi5 running 2 HSR-USB on ASL3.
MY problem is if node 1 or 2 are connected to another node they work perfectly. If nodes 1 and 2 are connected, then they knock each other off and one node’s green light will go solid. Also, the CLI continuously show the following error:
[2025-12-30 17:33:20.484] ERROR[1449]: chan_simpleusb.c:996 hidthread: Channel 653266: Device string 3-1:1.0 is already assigned to channel 653267
NOTE: I have 3 SHARI PiHatU that all have an HSR-USB plugged into them and they work great, which leads me to believe that I have something wrong in my setup of this one.
HELP, Please.
asl-find-sound
1-2:1.0 --> 0d8c:0012 C-Media Electronics Inc.
3-1:1.0 --> 0d8c:0012 C-Media Electronics Inc.
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 012: ID 0d8c:0012 C-Media Electronics, Inc. USB Audio Device
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 012: ID 0d8c:0012 C-Media Electronics, Inc. USB Audio Device
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
653266
;;;;; ASL3 Tune settings ;;;;;
devstr = 3-1:1.0
;rxmixerset=500
;txmixaset=500
;txmixbset=500
653267
;;;;; Tune settings ;;;;;
devstr = 1-2:1.0
;rxmixerset = 500
;txmixaset = 500
;txmixbset = 500
To clarify, are you connecting nodes 1 and 2 to each other? or both nodes to other nodes?
Also, can you confirm that your /etc/asterisk/simpleusb.conf file only includes the two "devstr = ...." statements? Maybe, rather than copy/pasting a subset of the .conf file you could Upload a copy of the entire file?
The nodes are connected to nodes like ECR, DoDropIn, etc
simpleusb.conf (8.8 KB)
My New Year’s resolution is to stop being an idiot…I swapped to a better power supply, and everything works as it should.
Thanks for the time and effort, and sorry for the waste of your time and effort.
Brian - W4PTZ
