Mtr2000 simple usb
I would like to talk to anyone using a mtr2000 and simple usb. I am using the mtri connector and I would like to compare notes with other folks to see what other people’s experiences have been.
N1XBM
Apparare Scientor
Paratus Communicare
Allstar Node # 27086, 41540, 41812
OK,
I have an update, I was able to figure out the wireline card issue. I was having some strange issues, such as the station not always going into full duplex when it should, strange behavior. The station was also going into an error code about the wireline card being incompatible.
What I did to get everything work with the wireline card was.
  1. Created a default “clean” new codplug.
  2. I then programmed the station for the wireline card, inserted the card, then re-booted the station.
  3. The station still had a wireline card error. Next I did a alignment of the wireline card.
After all of that the MTR2000 works as it should using the wireline card.
N1XBM
Apparare Scientor
Paratus Communicare
N1XBM
Apparare Scientor
Paratus Communicare
Allstar Node # 27086, 41540, 41812, 42086, 42658, 42657
www.radioguysrepeaternetwork.com
