MSF-5000 with DMK URI
Has anyone been successful in adding a DMK URI to a MSS5000 repeater? I currently have a Arcom RC-210 controller that I’d like to remove and use just the URI interface.
When I try running the radio tune menu, #2 receiver audio fails. My thought is the level is to low, but I’m not sure how to get it any higher, or possible use a different point that has a higher audio level.
thanks,
Bob / KC0EFC
Node 27823
Do you have rxboost=1 in usbradio.conf? If so hopefully someone who is using a MSF can help you with finding a higher level audio.
Another option would be to switch to simpleusb and let the radio do COR and PL decode. Actually I prefer this as Motorola does a better job of PL decode.
Tim
:wq
thanks,
Bob / KC0EFC
Node 27823
ohnosec.org
Also don’t forget the URI has a general use 6 db audio amp onboard.
Robert Poff
Loganville, Pa
Droid X Mobile
Tim
:wq
thanks,
Bob / KC0EFC
Node 27823
ohnosec.org
Bob,
Sounds like DC is on the audio line. Place a .1uf cap in series
Chuck K0XM
Tim
:wq
thanks,
Bob / KC0EFC
Node 27823
