Wow,
I thought this was déjà vu for a moment because I actually thought I wrote
the email that Michael wrote as I went through the exact thing last night. I
installed an Belkin Hi-Speen USB 2.0 Dual-Port PCI card in my Asus box in
the hopes that this would solve my motorboating problem because I just have
no other idea what could be causing this motorboating issue on all of these
boxes (same ASUS motherboard) and have exhausted all other options as far as
I know.
So I also had no audio as described my Michael, so since I really had
nothing to lose, I just reinstalled the entire package and that got the
audio working and when it did work, the motorboating issue seemed to be
completely gone!
The only problem that I had was that after a period of time, the audio and
telemetry would just stop working again. If I restarted asterisk, it would
return most of the time.. Worse case, I would reboot the box and it would
also return but to only disappear minutes later.
So I finally gave up and just found another box that did not use the same
ASUS motherboard to get my next node built.. Since I do have 8 of these
boxes, I would like to find a solution though as I really would hate to toss
them out and I have 8 nodes to deploy here in South Florida.
If anyone knows of a USB card that does work, let me know and I will try
it.. I did read that some of these cards will only do USB 1.1 under Centos
5.5 and above.. Not sure if that could be the issue? Are we supposed to be
USB 2.0 with the URI?
I am going to look at what Paul suggested one more time with this USB card
just in case, but since it does work for a short time, I figured that it
must be configured correctly, no?
I would appreciate any comments.
Thanks and 73
Lu
KA4EPS ..
-----Original Message-----
[mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Paul J. Agamata
Sent: Sunday, July 17, 2011 7:57 AM
To: jrorke@cogeco.ca; APP_RPT_Users
Subject: Re: [App_rpt-users] Moving URI between USB ports.
do a 'dmesg | grep usb' and you'll ge this:
usbcore: registered new driver usbfs
usbcore: registered new driver hub
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
usb usb1: configuration #1 chosen from 1 choice
usb usb2: configuration #1 chosen from 1 choice
usb usb3: configuration #1 chosen from 1 choice
usb usb4: configuration #1 chosen from 1 choice
usb usb5: configuration #1 chosen from 1 choice
usb 3-1: new full speed USB device using uhci_hcd and address 2
usb 3-1: configuration #1 chosen from 1 choice
input: USB HID v1.00 Device [C-Media Electronics Inc. USB PnP Sound
Device] on usb-0000:00:1d.1-1
usbcore: registered new driver snd-usb-audio
Notice the usb 3-1 before the C-Media Electronic Inc. device.... That's the
address of your URI
In your usbradio_tune_usb0.conf file make sure you match the new devices
port address to this listed below:
[usb0]
; name=usb0
; devicenum=0
devstr=3-1 <============== Make sure it has the port
address of the new port you plugged it in to
rxmixerset=438
txmixaset=407
txmixbset=0
rxvoiceadj=1.263154
rxctcssadj=2.154079
txctcssadj=199
rxsquelchadj=900
restart asterisk....
If you don't get the device address right, all your tuning parameters will
be thrown off as well.
_______________________________
Paul Agamata
Sysman@Xceptions.COM
________________________________________
From: app_rpt-users-bounces@ohnosec.org [app_rpt-users-bounces@ohnosec.org]
On Behalf Of REDBUTTON_CTRL [jrorke@cogeco.ca]
Sent: Sunday, July 17, 2011 1:21 AM
To: APP_RPT_Users
Hi Michael, I tried a PCI 4 port USB card and didn't have much luck with
it. Not to say they don't work, but I never got it to work properly.
I did make sure that it was USB 2.0.
You might want to try to make a small adjustment to your radio tune file
like bumping the squelch setting by 1 notch, then re-saving. That will
update your radio tune file with the current USB port.
As example, if your squelch was set to 850 do a "radio tune rxsquelch 851"
Then save with "radio tune save".
Perhaps restart Asterisk and see if that works.
I have always relied on PCs that are P4 3G boxes that have 4 - 6 USB 2.0
ports on board and have had no trouble there.
What is the speed of your box? Does it meet the min specs? USB ports
must be 2.0 or you will have problems.
Regards,
Jon VA3RQ
On 7/17/2011 3:23 AM, Michael Carey wrote:
Hi Everybody,
In an attempt to fix a random "motorboating" audio issue on transmit I
have with my new AllStarLink node, I fitted a PCI USB2.0 board (NEC
chipset) to the computer.
CentOS found the new card fine. I shifted my URI to one of the new USB
ports and everything seems to be working... EXCEPT I am not getting
any transmitted audio.
Receive audio is fine, the radio will key up OK... but I get no
telemetry tones nor any incoming audio.
What needs to be done when you move a URI to another USB port? Why
would receive audio be fine and transmitted audio not?
Please be gentle, I am still a little green with this new stuff.
Michael.
VK5ZEA
ohnosec.org
