I am VERY close to setting up my ASL node, however…I tried to modify a CM108 (this time correctly) but…it didn’t work. Allmon kept saying, whenever I plugged in my CM108 card, that it detected the COS signal and it keyed the PTT, however, I know that both of these were false. I constructed it following this link here: How To Modify A CM108 for Allstar latest version - allstar setup.com %.
Is there something I am doing wrong? What are the correct pins that should be connected to the SM50?
I have verified that the logic levels are correct and that I’ve connected the radio to the right pins. Any opinions on the RepeaterBuilder RIM-USB fobs? I have some more CM108s but I’d rather not burn through them although they’re like a dollar a piece and perhaps a pre-made solution would be best.
I am not sure if this will still be helpful as the post is a bit old but I had tried the link you shared and for some reason I couldn’t get it working on baofeng 888 or baofeng uv82.
