Motorola R1225 to USB-Rim Lite Interface Question
I’ve searched and read and searched some more and still am having issues with audio from the repeater passing through.
Recently ordered one of the USB-Rim Lite’s from repeater builder to interface a Motorola R1225 repeater to ASL.
I’ve built cables and used both the RA-33 and AriUSB for interfacing previously. With this one, I’m stumped.
Looking for info (radio wide configuration, external accessories, simple-usb values) on the values from someone who has used this setup.
I don’t run the USB-Rim Lite interface. I use the R1-2023 from avrtx. But here is a screen my configuration on the R1225 repeater(RKR1225) version.
Radio Wide:
Pwr UpMode: Standard
Unmute/Mute Type: AND/OR
Operation Mode: Uni-directional
Rpt Audio Mode: EIA
Under enable option uncheck every box
External Acc.
Acc External: General I/O
Pwr-up Delay:2.5
Rx Audio Output: De-emphasized
Rx audio Muting: Muted
External Mic: External Mic Audio
Tx Flat Audio Input: Pre
Page PTT Tx Audio: Flat Tx Audio
Pin 6: Page PTT ; Debounce On, Active Low
Pin 8: PL/DPL-CSQ Detect, Direction: Output, Active Low
