Given app_rpt’s ability to generate all manner of courtesy tones, I was thinking about a broader idea.
Had anyone had success at emulating Motorola Quick Call tones using app_rpt?
I’ve been thinking about creating an extensions stanza and script that would grab a message that was recorded, then play QCII tones over the air to unsquelch a Minitor and play the audio file that was left.
It is possible to generate any tone/sequence via SOX to a file that can be played as a sound file.
You will need to see the SOX documentation.
I have done this with DTMF and others so multiple tones can be generated simultaneously.
But to do it by command may require some crafty scripting.
Unless you just use a few pre-recorded sound files. But even that would require some light scripting.or just command creation.
Yeah, I was thinking of generating the tone pairs with SOX. I’m reasonably good with SOX, it’s a powerful beast. Since it’s pretty much for myself I can pick a tone pair (or whatever pair is left in the Minitor) and hard-code it.
Scripts are no problem…you should see how I automate the capture and playback of amateur radio news services whose audio levels are ALL OVER THE PLACE.
I guess my follow-on question is: Can you execute a script within a stanza in extensions,conf?
EDIT: Answered my own question with a two-second search:
While it is more convenient to execute from extensions.conf and have the full asterisk dialplan commands when you know how to get there,
you may also run a script file from a single command in rpt.conf
xxx=cmd,/path/to script.sh were xxx is the command number you assign.
