[ I'm resending this to the group. I hate that replies go only to the original sender. ]
The version of the chan_irlp software I'm running has all the support functions that a normal IRLP node has. Therefore, the same methods are used. Place the node you want to lock out in the $CUSTOM/lockout_list file. For example, to lockout node 1234, put stn1234 in the the above mentioned file. If you want to lockout all reflectors, put ALLREF in the file.
This will prevent calling or receiving calls from the listed nodes.
ยทยทยท
On Apr 10, 2009, at 9:51 AM, Matt Beasant wrote:
Hi Stephen,
Yes I see that such a timer exists for the remote base but not for a "regular" node.
Is there a way I can block connections to a specific node on IRLP ( or Echolink )?
Just wondering if that might be good for a temporary work around.
Matt
G4RKY
App_rpt-users@qrvc.com
Randy Hammock KC6HUR
http://kc6hur.net/~rhammock/
http://irlp.kc6hur.net/
If there are no horses in heaven, then when I die, I want to go where they went.
