Perhaps clear you browser cache and/or turn off any script blocking. Try again.
Your first looking check should be the nodes list you already have /var/lib/asterisk/rpt_extnodes
along with the timestamp of the file to be sure it is recent.
then perhaps the website.
Have tried Firefox, Edge and Brave. Cleared caches and reloaded status page on all 3, Still no listing of MY node but others display fine. I don’t get it…
Based on the info presented,
you are likely left with firewall/routing/dns type issues.
Try the same from your cellphone using ‘cellular data’ and not wifi behind your NAT.
(turn off the wifi and any auto switching capability to use wifi)
But, it is likely in the router or routing problems in some way in common.
Everything behind your NAT should be a clue to that
But if not, your ISP with similar issues.
You are not using a standard ISP are you, but a highly tagged private network with lots of it’s own routing ?
