Modulation Issue
I wanted to throw this question out there and see if anyone could help.
I am trying to use the XIPPR distribution of Centos from XELATEC, LLC.
that appears to have some neat features. However when we connect a URI
from DMK Engineering we are only getting about 1/2 volt peak to peak and
.7 volts peek to peak if we run the audio through the amplifier.
As a test we download the ACID distribution from app-rpt.qrvc.com and we
get about 1.7 volts peak to peak direct and about 3.2 volts peak to peak
Anyone know where I would start to look at why just using a different
Linux distribution would break this? Also if it turns out to be the
USBRADIO.c driver, how would I go about recompiling an updated version?
Ted/KE6YJC
Ted/KE6YJC
App_rpt-users@qrvc.com
We don't spend time tracking what changes Steve Henke has made to XIPPR, but my guess is that the files in the
asterisk/channels/xpmr directory are very likely to be significantly different between the two distributions.
XIPPR and ACID are forks and changes are not "cross pollinated" between them. We don't have the time nor the resources
to devote to that.
Steve
WA6ZFT
