I’m looking for a good mini ITX solution for Asterisk/app_rpt. I had been using Intel D525 CPU/motherboard but those are getting hard to find. What’s a good motherboard/CPU combo for Linux these days?
Tim
:wq
Tim
:wq
Tim,
I’ve had success running the Intel D2500HN board with Linux. Here is a link to a few mini ITX boards that should all work with Linux:
Tim
:wq
Andrew Sylthe
KC9ONA
Hi,
Most Mini-ITX boards will work well with Linux but watch out for
overheating chips, the South Bridge / VGA controller, in particular. Many
of these boards don't have a heatsink on the South Bridge and will burn up
(or lock up!) in short order in an already hot repeater cabinet.
At least the solution is simple! Attach a small adhesive-backed heatsink
to the hot chips and this problem is usually eliminated. Ebay sells a big
selection of these heatsinks.
73, David KB4FXC
On Tue, 19 Aug 2014, Andrew Sylthe wrote:
Tim,
I've had success running the Intel D2500HN board with Linux. Here is a
link to a few mini ITX boards that should all work with Linux:On Tue, Aug 19, 2014 at 3:46 PM, Tim Sawyer <tim.sawyer@mac.com> wrote:
> Tim
> :wq
> App_rpt-users mailing list
> App_rpt-users@ohnosec.org
> "Unsubscribe or edit options button"
> You do not need a password to unsubscribe, you can do it via email
> confirmation. If you have trouble unsubscribing, please send a message to
> the list detailing the problem.
A friend bought a Biostar nm70i-1037u which appears not to boot ACID.
Tim
:wq
On Aug 19, 2014, at 2:27 PM, David McGough kb4fxc@inttek.net wrote:
Hi,
of these boards don’t have a heatsink on the South Bridge and will burn up
(or lock up!) in short order in an already hot repeater cabinet.At least the solution is simple! Attach a small adhesive-backed heatsink
selection of these heatsinks.73, David KB4FXC
Tim,
link to a few mini ITX boards that should all work with Linux:On Tue, Aug 19, 2014 at 3:46 PM, Tim Sawyer tim.sawyer@mac.com wrote:
a good motherboard/CPU combo for Linux these days?Tim
:wq
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usersTo unsubscribe from this list please visit
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usersTo unsubscribe from this list please visit http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button”
This is my experience too. I have tried several using the NM70 chipset, and NONE of them worked. (Fine on Rx but no audio on Tx). I have used several with the NM10 chipset (which are for atom processors) and they have all worked without any trouble.
73 Willem
Dr. Willem A. Schreuder, President, Principia Mathematica
Address: 445 Union Blvd, Suite 230, Lakewood, CO 80228, USA
Tel: (303) 716-3573 Fax: (303) 716-3575
WWW: www.prinmath.com Email: Willem.Schreuder@prinmath.com
This one worked for me
http://www.amazon.com/gp/product/B00ECK4A5A/ref=oh_aui_detailpage_o00_s00?ie
=UTF8&psc=1
It uses the NM10 chip set. And is in place running a repeater as we speak.
Runs fairly cool. I have a small case fan on it to move air by the heat sink
on the CPU in the hot repeater shack.
I've not had good experiences with the Celeron with the NM70 chip set such
as
http://www.amazon.com/gp/product/B00D1A8094/ref=oh_aui_detailpage_o03_s00?ie
=UTF8&psc=1
which does not work with the audio devices like the URI
Bob
kk6ecm
-----Original Message-----
[mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Willem Schreuder
Sent: Tuesday, August 19, 2014 2:43 PM
To: Tim Sawyer
Cc: APP RPT
Subject: Re: [App_rpt-users] Mini ITX Choice -- warning!
73 Willem
the bottom of the page. Enter your email address and press the "Unsubscribe
Hi,
We using a SUPERMICRO X7SPA-HF-D525
This is a Mini-ITX with Intel Atom D525 and 2 x Gigabit LAN.
We are very happy with this board.
Passive Cooling, but we have 2 Fans inside of the Case.
For remote install, Administration is IPMI onBoard.
Here technical data:
Motherboard - Mini-ITX
CPU
Intel Atom D525 / 1.8 GHz (Dual-Core)
Chipset
Intel ICH9R
Max. RAM
4 GB
RAM
2 SO-DIMM-204 pole
DDR3
non-ECC
unbuffered
PC3-6400
800 MHz
1.5 V
Connectors
6 x SATA-300 (RAID 0 / RAID 1 / RAID 10 / RAID 5)
3 x USB 2.0 + (5 x USB 2.0 internal)
1 x PCIe x16
1 x VGA
1 x PS/2-Keyboard
1 x PS/2-Mouse
1 x RS232 + (1x RS232 internal)
Graphic
Matrox MGA G200eW
LAN
2 x Gigabit Ethernet (2 x Intel 82574L)
73 DL1FLO, Florian
Am 19.08.2014 um 22:46 schrieb Tim Sawyer tim.sawyer@mac.com:
Tim
:wq
Tim, I just recently tried something off-beat, and not for everyone. I have in the past used D945 Intel boards in a Mini M200 case with a CPU blower and a case side blower. But you have to get decent fans, most of the stuff out there will expire quickly and you get overheating and shutdown. I have node 2360 running on one of these with Limey on it, no problems after I changed the fans. Also the right pico power supply is necessary. There are a couple of models that make the 12 volts. Most seems to pass the 12V along from the outside power supply. If that wiggles a bit low, the CPU power source goes bonkers and you have a lockup/shut down, etc. But the ones that have not only wide input but down to 6V are the ones to get. They just run and run and very cool.
OK, that all said, background, I linked two sites using something called DRIL, adapted from openh323 by Armadillo in Texas. Worked ok, but a CPU killer, ran at 100% always. Built on a WYSE/Netier thin client box. Then I discovered Allstar and the above setup. But I recently saw a WYSE thin client on eBay in a nice package. Has 128MB od flash drive and I stuck a gig of ram in, made a version of Limey to run it and tried it and it was great. Going to modify my node to it sooner or later. Cost? $15, including power supply and a very nice small package. Two nodes in it? CPU a bit small. DSP audio? Probably not. Didn’t even try.
Buy all new stuff? I’d go with one of the Intel 2500 boards a M200 case ans a PicoPSU60WI flash module and Limey.
GeorgeC
George J Csahanin
W2DB
Cedar Park, TX
512-401-2630 home
401-338-0568 cel
Sent: Tuesday, August 19, 2014 3:46 PM
To: APP RPT
Subject: [App_rpt-users] Mini ITX Choice
Tim
:wq
I agree with your recommendation. I have 8 D2500HN some have
4 radios attached. Each board has the Intel logo not the MITAC logo.
JK
To: "Tim Sawyer" <tim.sawyer@mac.com>
Cc: "APP RPT" <app_rpt-users@ohnosec.org>
Date: Tuesday, August 19, 2014, 5:05 PM
Tim,
http://www.mini-box.com/Atom
Tim
:wq
address and press the "Unsubscribe or edit options
button"
email confirmation. If you have trouble unsubscribing,
Andrew Sylthe
KC9ONA
-----Inline Attachment Follows-----
email address and press the "Unsubscribe or edit options
button"
I also have about a dozen D2500HN genuine Intel boards running. I find them to be very reliable as I have never had to replace one yet.
I stuff in 2G RAM and couple a 16 GB SSD to them.
Tastes great - less filling.
Kevin - W3KKC
JK--------------------------------------------
On Tue, 8/19/14, Andrew Sylthe <asylthe@kc9ona.com> wrote:Subject: Re: [App_rpt-users] Mini ITX Choice
Tim,
Atoms
I�m looking for a good mini
What�s a good motherboard/CPU combo for Linux these days?
Tim
:wq
button"
Andrew Sylthe
KC9ONA
button"
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usersTo unsubscribe from this list please visit http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
You do not need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem.-----
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2014.0.4745 / Virus Database: 4007/8068 - Release Date: 08/20/14
I just put a Biostar NM70I-1037U into service as a hub and RTCM host (no USB).
It couldn’t read the CDROM until turning on AHCI. No install problems other than that.
These have a Celeron which run at a higher CPU voltage than the ATOM. Someone said they think the higher CPU voltage is less susceptible to RF crashing the system. Requires a CPU fan and a higher power PS than the ATOM.
It’s looking like a pretty good choice in the speed department:
*CLI> core show translation
Translation times between formats (in milliseconds) for one second of data
Source Format (Rows) Destination Format (Columns)
g723 gsm ulaw alaw g726aal2 adpcm slin lpc10 g729 speex ilbc g726 g722
g723 - - - - - - - - - - - - -
gsm - - 2 2 2 2 1 - - - - 2 -
ulaw - 2 - 1 2 2 1 - - - - 2 -
alaw - 2 1 - 2 2 1 - - - - 2 -
g726aal2 - 2 2 2 - 2 1 - - - - 1 -
adpcm - 2 2 2 2 - 1 - - - - 2 -
slin - 1 1 1 1 1 - - - - - 1 -
lpc10 - - - - - - - - - - - - -
g729 - - - - - - - - - - - - -
speex - - - - - - - - - - - - -
ilbc - - - - - - - - - - - - -
g726 - 2 2 2 1 2 1 - - - - - -
g722 - - - - - - - - - - - - -
Tim
:wq
I stuff in 2G RAM and couple a 16 GB SSD to them.Tastes great - less filling.
Kevin - W3KKC
JK
To: “Tim Sawyer” tim.sawyer@mac.com
Cc: “APP RPT” app_rpt-users@ohnosec.org
Tim,
On Tue, Aug 19, 2014 > > at 3:46 PM, Tim Sawyer tim.sawyer@mac.com > > wrote:
Tim
:wq
