Migration Issues
I just migrated one of my nodes from ACID to DIAL. It is up and running fine but I have a couple of things that need to be addressed.
First, it is no longer showing up on the Allstar Status Pages. When I connected it to one of my other nodes the Allstar site showed the correct info in the bubble display. Is there a command I can run to force registration or is there
a logfile that might show errors?
Second, during the install I saw where it was trying to sync to time servers. I block access to time servers external to my network since I have a Stratum 1 NTP server on my network. Where can I change the NTP settings? I am not a Linux
guru so a full path is appreciated.
Jamey Wright – WR4JW
Hello Jamey, If your time is off it might not connect to the ASL servers… If you have ntp installed you can edit the /etc/ntp.conf and make the changes there. If your using a DHCP make the changes to your DHCP server.
David
KE6UPI
On Fri, Jan 6, 2017 at 10:54 AM, Jamey Wright Jamey.Wright@morgan911.org wrote:
You can try to use the command “find”.
find / -name ntp.conf I don’t think DIAL has NTP install by default. Sorry I’m not a Debian user.
It looks like Debian uses ntpdate. You can edit /etc/default/ntpdate.
David
KE6UPI
On Fri, Jan 6, 2017 at 7:09 PM, Jamey Wright Jamey.Wright@morgan911.org wrote:
It says NTP is installed but there is no ntp.conf in /etc
Jamey Wright - WR4JW
From: shawpbx@gmail.com [shawpbx@gmail.com] on behalf of David KE6UPI [dshaw@ke6upi.com]
Sent: Friday, January 06, 2017 7:30 PM
To: Jamey Wright
Cc: App_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Migration Issues
David
KE6UPI
Jamey, Did you get the time servers worked out??
David
David
KE6UPI
To: Jamey Wright
David
KE6UPI
