I link two asterisk systems here on two different computers. One is an allstar server the other is an asterisk pbx. They are linked with iax and that is what is shown above.
There is a ton of info and books on Asterisk out there. I have been using Asterisk as my home pbx for years and have it linked to X10 and many other home control systems. This can all be linked to the radio if desired.
73 Doug
WA3DSP
Date: Thu, 20 Feb 2014 17:08:47 -0600
To: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] method for making calls to asterisk
On 02/20/2014 03:33 PM, mike@midnighteng.com wrote:
I remember a message some time ago related to this but I
did not save it??? Thought I did ???
Background - I am trying to automate a few things.
I'm looking for a way to make a call "directly to asterisk"
via app_rpt command ?
For instance, connecting to a iax or sip extension ?
In order to pass a command directly to a running instance of
Asterisk
#> asterisk -rx "rpt nodes 2000"
(for example, if you were at the command prompt of the machine that
houses node 2000)
Makes it easy to schedule things in cron, as well. Better to let
the OS handle things
I have hourly chimes, that play from 6am till 10pm, Monday thru
Friday.
It looks like:
0 6-22 * * 1-5 /usr/sbin/asterisk -rx "rpt fun 29655 *81"
The fields are documented all over but for the sake of ease of
finding it…
The time and date fields are:
field
allowed values
minute` `0-59
hour` `0-23
day of month` `1-31
month` ` 1-12 (or names,
see below)
day of week` ` 0-7 (0 or 7 is
Sun, or use names)
A field may be an asterisk (*), which always stands for
``first-last’'.
Ranges of numbers are allowed. Ranges are two numbers
separated with a hyphen. The specified range is inclusive. For
example, 8-11 for an ``hours’’ entry specifies execution at hours
8, 9, 10 and 11.
Lists are allowed. A list is a set of numbers (or ranges)
separated by commas. Examples: 1,2,5,9'',
0-4,8-12’'.
Step values can be used in conjunction with ranges.
Following a range with /'' specifies skips of the number's value through the range. For example,
0-23/2’’ can be
used in the hours field to specify command execution every other
hour (the alternative in the V7 standard is
0,2,4,6,8,10,12,14,16,18,20,22''). Steps are also permitted after an asterisk, so if you want to say
every two hours’‘,
just use ``*/2’'.
Names can also be used for the ``month'' and ``day of
week’’ fields. Use the first three letters of the particular day
or month (case doesn’t matter). Ranges or lists of names are not
allowed.
The ``sixth'' field (the rest of the line) specifies the
command to be run. The entire command portion of the line, up to a
newline or % character, will be executed by /bin/sh or by the
shell specified in the SHELL variable of the cronfile.
Percent-signs (%) in the command, unless escaped with backslash
(), will be changed into newline characters, and all data after
the first % will be sent to the command as standard input.
Note: The day of a command's execution can be specified by
two fields — day of month, and day of week. If both fields are
restricted (ie, aren’t *), the command will be run when either field
matches the current time. For example,
``30 4 1,15 * 5'' would cause a command to be run at 4:30 am on
the 1st and 15th of each month, plus every Friday.
All that being said, you can set a crontab to do what you want,
when you want it done.
-Geoff/W5OMR
To unsubscribe from this list please visit ohnosec.org and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button”
