M1KE Allstar Support
Hi group. I'm a long time Allstar user. Recently with V26 the M1KE now supports connecting to Allstar. In order to configure the connection it's asking for a token from the Allstar network. I'll be darned if I can the Request a token button that the M1KE mentions. Can anyone help me with this. Thanks in advance.
73,
K9AT
Nevermind. I was over thinking this. The token is generated with the M1KE and not on the Allstar site. Thanks!
I appreciate the clarification.
This works great!! The M1KE ROCKS!!!
I just upgraded to V26 of the M1KE but do I need to sign up for an allstar account. Asking for my call sign and password.
Yes you need to register with Allstar.org. Once you do that then enter those credentials into the M1KE then it will generate the token. The default port is 4569. This is perfect for me because I have a repeater that's connected to the Allstar network. As another option if you're an iOS guy then there's a nifty app call repeater phone that costs I think $8 and this will connect you with not only all of the Allstar connections but the Echolink ones too. It's a cool app and worth the money. 73 K9AT
What is M1KE? never saw that
GeorgeC
I will find out in a few hours....Mine is in Phoenix! Were there directions for that anywhere?
The M1KE is a new product from the guys at SharkRF.com. It's an HT and a hotspot all in one. They're really popular because you don't need to use a separate HT to transmit into the hot spot like their Open Spot4. The drawback to the M1KE vs. the Open Spot is it works on on WiFi unlike an HT that will uses RF. Finally the M1KE doesn't support P25 like the Open Spot 4's. Hope this helps and answers your questions.
73,
David
K9AT
The directions are at SharkRF.com.
Oh. I am an old user from when allstar was connecting repeaters
Sounds like a cross between a crippled network radio and a crippled hotspot...
Really? It adds additional functionality to an already popular SharkRF product. The v26 firmware was free. If I was on the M1KE talking to you, you could tell as the audio is excellent. Let's be a little more open to change...
I'm just saying it sounds like it already does what a network radio has been doing for several years except no P25.
The M1KE is different than the usual hotspots in that it's a hotspot AND a WiFi radio HT. That's revolutionary.
I cant register on Allstarlink
It wont accept my callsign, M1MWD
Any help appreciated
Please open a ticket with helpdesk.allstarlink.org for account support.
Check back for a followup from the Helpdesk; I completely misunderstood what you were trying to say there.
For those who get a M1KE.
I had a hair pulling time of it till I realized I needed to use teh passwsord I use to connecto allstarlink org.. NOT the password for the node. That worked.> Token grabbed. Working great. If you use allstar under more than one profile you may need to request (same token) for each profile.
Did the same thing John so you're not alone...
