This is not really an ASL issue.
What radio(s) are you receiving your node sa818 with? This absolutely matters.
If your radio has PL decoding enabled, and have programmed the sa818 with "reverse burst" enabled, which is really not that at all, it's actually STE, then the sa818 sends an odd tone burst at the end of transmissions. This is a 59 Hz tone that lasts for about 300 milliseconds.
Some radios will quietly close their CTCSS decoders when they encounter it. Others won't.
Examples of radios that don't include Baofeng and many other low-end Chinese radios, and Yaesu.
My Kenwoods, Icoms and radios running OpenGD77, such as my TYT MD-UV380, do, however.
If the sa818 put out a 55 Hz tone instead of a 59 Hz one, this would be a different story. Pretty much everything likes that tone, as many Chinese radios are set up to close squelch as soon as they hear it, even without CTCSS decoding enabled. It's more likely to work even than reverse burst or notone, where the tone drops out before the carrier.
I have actually been meaning to do a feature request in ASL3's usbradio driver to add 55 Hz STE as an option. Then you could, assuming you have a V1.2 (generic) or V5.5 (SHARI) firmware version of the sa818 radio, which is baseband, use usbradio to do the CTCSS encode and decode rather than your radio's PL using usbradio, then select this 55 Hz STE instead of notone or reverse burst, then almost no radio in existence would crash like that. Yaesu radios still would, though, unless the burst is about 500 MS long. They are just ridiculously bad about that.
So, unfortunately, my best advice would be to try other radios for receiving, or use something better than the sa818 on the node.
The Retevis RT85 as a node radio, or set of radios, sends out the 55 Hz STE that most radios like. DCS would be even better in that case, since ASL3's simpleusb radio doesn't have a delay line to eliminate squelch bursts received by the node, I.E. what others hear when you transmit to it. This can be fixed by using usbradio and manually configuring things in the configuration file, like rxsquelchdelay = 200 (the setting I've found to mwork very well with my ANF101M and RT85's) and opening the RX and TX HPF/LPF filters as far as they go for best audio quality, but that won't help you as far as you receiving squelch bursts from your radio at the end of node transmissions.
Unfortunately, I can't even tell you to use DCS on the sa818, which should solve that problem, because the sa818 doesn't properly implement DCS. All radios that use that method should send a 134.4 Hz tone at the end of transmissions, which breaks the coded squelch. The sa818, even when set to DCS, still sends a 59 Hz tone, so you'll still get that static crash.
Squelch tails are my enemy. I have done lots of things to insure no one will ever hear one of those from any of my nodes, and likewise, that I won't hear it from my nodes, either.
Using better radios makes this easier, but that's not always possible.
