I looked through all the archives and the admin manual for app_rpt (as
well as trying to decipher rpt.conf) to enable the temperature
or other sensor (i/o) functions but I couldn't locate the info;
LM-34 temperature wiring and/or function.
Can someone that is using this function please copy and paste your
section in rpt.conf that makes this work?
I already have the LM-34 connected to pin 2 or the URL (as well as +
and gnd), but I don't know how to interrogate it.
Direct connection of an LM34 to the URI is not supported.
There is some experimental code in app_rpt.c to use the uChameleon
USB DAQ device. The uChameleon has analog input channels which might be able to be used with the LM34
with a little bit of signal conditioning. Non of this has been tried.
