LiTZ Usage
How is the new LiTZ feature implemented? I’ve updated to the latest
code in the repository, but I don’t see any examples in the config
files, unless I looked over it?
I’d like to start experimenting with this, I’ve got a SIP phone hanging
off of my app_rpt box that I would like to make ring in response to a
LiTZ event for example.
Anyone have any config examples?
tnx and 73
Stephen
K1LNX
Stephen Brown - ARS K1LNX
Johnson City, TN EM86
http://www.k1lnx.net
google voice: 423-665-9367
sip: sbrown@voip.stephennet.net
An update, this was easier than I thought, I dug through the source a bit and figured it out I think.
Add litzcmd=dosomethinghere to your node stanza in rpt.conf
For example in mine, I have it set to ring my SIP phone with *62:
litzcmd=*62 ; Long Tone Zero, ring node operator’s SIP phone
You should see something similar to this in the Asterisk console:
[Feb 16 20:49:30] NOTICE[18459]: chan_usbradio.c:2440 usbradio_read: Got DTMF char 0 duration 3455 ms
[Feb 16 20:49:30] NOTICE[18459]: app_rpt.c:16933 rpt: Doing litz command *62 on node 2335
Very slick, I could see a million different ways to implement this!!!
Stephen
K1LNX
tnx and 73
Stephen
K1LNX
You can also find a write up here:
http://app-rpt.qrvc.com/node/171
Jim, K6JWN
Stephen
K1LNX
tnx and 73
Stephen
K1LNX
App_rpt-users@qrvc.com
Jim Nessen K6JWN
Email: nessenj@jimsoffice.org | Ph: 530.564.0039
IRLP: Nodes 3598,7358 | Echolink: 83598 K6JWN-R
