Is there a way to define a listen-only (monitor only) IAX extension in extensions.conf?
I provide VOX extensions for IAX (Zoiper, etc.) users. This works:
exten => 1234,1,answer()
exten => 1234,n,Wait(1)
exten => 1234,n,Playback(rpt/connected)
exten => 1234,n,rpt(1000|Pv)
For listen-only, maybe use the S “Simplex dumb phone control mode” and find a way to disable the * and # DTMF commands for transmit?
Glancing at app_rpt.c source code, I don’t see an obvious option for a listen-only extension:
" Not specifying an option puts it in normal endpoint mode (where source\n"
" IP and nodename are verified).\n"
" Options are as follows:\n"
" X - Normal endpoint mode WITHOUT security check. Only specify\n"
" this if you have checked security already (like with an IAX2\n"
" user/password or something).\n"
" Rannounce-string[|timeout[|timeout-destination]] - Amateur Radio\n"
" Reverse Autopatch. Caller is put on hold, and announcement (as\n"
" specified by the 'announce-string') is played on radio system.\n"
" Users of radio system can access autopatch, dial specified\n"
" code, and pick up call. Announce-string is list of names of\n"
" recordings, or \"PARKED\" to substitute code for un-parking,\n"
" or \"NODE\" to substitute node number.\n"
" P - Phone Control mode. This allows a regular phone user to have\n"
" full control and audio access to the radio system. For the\n"
" user to have DTMF control, the 'phone_functions' parameter\n"
" must be specified for the node in 'rpt.conf'. An additional\n"
" function (cop,6) must be listed so that PTT control is available.\n"
" D - Dumb Phone Control mode. This allows a regular phone user to\n"
" have full control and audio access to the radio system. In this\n"
" mode, the PTT is activated for the entire length of the call.\n"
" For the user to have DTMF control (not generally recomended in\n"
" this mode), the 'dphone_functions' parameter must be specified\n"
" for the node in 'rpt.conf'. Otherwise no DTMF control will be\n"
" available to the phone user.\n"
" S - Simplex Dumb Phone Control mode. This allows a regular phone user\n"
" audio-only access to the radio system. In this mode, the\n"
" transmitter is toggled on and off when the phone user presses the\n"
" funcchar (*) key on the telephone set. In addition, the transmitter\n"
" will turn off if the endchar (#) key is pressed. When a user first\n"
" calls in, the transmitter will be off, and the user can listen for\n"
" radio traffic. When the user wants to transmit, they press the *\n"
" key, start talking, then press the * key again or the # key to turn\n"
" the transmitter off. No other functions can be executed by the\n"
" user on the phone when this mode is selected. Note: If your\n"
" radio system is full-duplex, we recommend using either P or D\n"
" modes as they provide more flexibility.\n"
" V - Set Asterisk channel variable for specified node ( e.g. rpt(2000|V|foo=bar) ).\n"
" q - Query Status. Sets channel variables and returns + 101 in plan.\n"
" M - Memory Channel Steer as MXX where XX is the memory channel number.\n"
" * - Alt Macro to execute (e.g. *7 for status)\n"
