AH6LE
April 6, 2024, 4:53pm
1
I recently moved to Debian 12 and ever since, neither Echolink nor ASL itself registers with their respective registration servers. I’m using the EXACT same config files in 12 as I used in 11. Same router, same port forwards, same IP, etc.
The logs report the connection to http://stats.allstarlink.org fails with error 422 and
ERROR[519] chan_echolink.c: One of the Echolink servers missing.
All port forwards are correct as needed and I’m stumped.
AH6LE
April 6, 2024, 7:54pm
2
I think the error is being reported by the stats server itself
I used the complete URL from the log entry that failed and ran it from the bash shell. to wit:
root@debian12ASL:~# wget http://stats.allstarlink.org/uhandler.php?node=1100&time=1712432633&seqno=21&nodes=T1101,T57387,T1002,T1103,T1102&apprptvers=2.0.0&apprptuptime=205&totalkerchunks=0&totalkeyups=0&totaltxtime=0&timeouts=0&totalexecdcommands=6
wget-log shows:
root@debian12ASL:~# more wget-log
–2024-04-06 12:45:59-- http://stats.allstarlink.org/uhandler.php?node=1100
Resolving stats.allstarlink.org (stats.allstarlink.org )… 34.105.111.212
Connecting to stats.allstarlink.org (stats.allstarlink.org )|34.105.111.212|:80… connected.
HTTP request sent, awaiting response… 422 Unprocessable Entity
2024-04-06 12:45:59 ERROR 422: Unprocessable Entity.
Why?
AH6LE
April 7, 2024, 3:08pm
3
Ahhh… 422 is the registration server saying it understands the command but the included data/syntax is bad.
Ok, now to figure THAT out…and why is is ok under Deb11 and not Deb12
kb4mdd
April 8, 2024, 12:38pm
4
Update your echolink.conf to include the following servers:
server1 = nasouth.echolink.org
server2 = naeast.echolink.org
server3 = servers.echolink.org
server4 = backup.echolink.org
AH6LE
April 8, 2024, 6:30pm
5
Nope, that didn’t make any difference
