[Sep 28 16:41:03] WARNING[32328] app_rpt.c: Reconnect Attempt to 29925 in process
[Sep 28 16:41:07] NOTICE[32317] chan_iax2.c: Auto-congesting call due to slow response
[Sep 28 16:41:13] WARNING[32328] app_rpt.c: Reconnect Attempt to 29925 in process
[Sep 28 16:41:17] NOTICE[32321] chan_iax2.c: Auto-congesting call due to slow response
[Sep 28 16:41:24] WARNING[32328] app_rpt.c: Reconnect Attempt to 29925 in process
[Sep 28 16:41:30] WARNING[32328] app_rpt.c: Reconnect Attempt to 29925 in process
[Sep 28 21:03:21] NOTICE[2195] cdr.c: CDR simple logging enabled.
[Sep 28 21:03:21] NOTICE[2195] loader.c: 53 modules will be loaded.
[Sep 28 21:03:21] WARNING[2195] chan_iax2.c: Unable to open IAX timing interface: No such file or directory
[Sep 28 21:03:21] WARNING[2195] acl.c: is not a valid IP
[Sep 28 21:03:21] ERROR[2195] codec_dahdi.c: Failed to open /dev/dahdi/transcode: No such file or directory
[Sep 28 21:03:21] NOTICE[2212] app_rpt.c: Normal Repeater Init 41715
[Sep 28 21:03:21] NOTICE[2212] app_rpt.c: Normal Repeater Init 41834
[Sep 28 21:03:21] WARNING[2267] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:21] ERROR[2267] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:21] WARNING[2266] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:21] ERROR[2266] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:22] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:03:22] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:03:22] WARNING[2278] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:22] ERROR[2278] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:22] WARNING[2277] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:22] ERROR[2277] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:24] NOTICE[2212] app_rpt.c: RPT thread restarted on 41715
[Sep 28 21:03:24] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:03:24] NOTICE[2212] app_rpt.c: RPT thread restarted on 41834
[Sep 28 21:03:24] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:03:24] WARNING[2423] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:24] ERROR[2423] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:24] WARNING[2422] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:24] ERROR[2422] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:26] NOTICE[2212] app_rpt.c: RPT thread restarted on 41715
[Sep 28 21:03:26] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:03:26] NOTICE[2212] app_rpt.c: RPT thread restarted on 41834
[Sep 28 21:03:26] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:03:26] WARNING[2554] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:26] ERROR[2554] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:26] WARNING[2555] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:26] ERROR[2555] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:28] NOTICE[2212] app_rpt.c: RPT thread restarted on 41715
[Sep 28 21:03:28] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:03:28] NOTICE[2212] app_rpt.c: RPT thread restarted on 41834
[Sep 28 21:03:28] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:03:28] WARNING[2557] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:28] ERROR[2557] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:28] WARNING[2558] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:28] ERROR[2558] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:30] NOTICE[2212] app_rpt.c: RPT thread restarted on 41715
[Sep 28 21:03:30] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:03:30] NOTICE[2212] app_rpt.c: RPT thread restarted on 41834
[Sep 28 21:03:30] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:03:30] WARNING[2572] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:30] ERROR[2572] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:30] WARNING[2573] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:30] ERROR[2573] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:32] NOTICE[2212] app_rpt.c: RPT thread restarted on 41715
[Sep 28 21:03:32] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:03:32] NOTICE[2212] app_rpt.c: RPT thread restarted on 41834
[Sep 28 21:03:32] WARNING[2212] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:03:32] WARNING[2606] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:32] ERROR[2606] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:32] WARNING[2605] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:03:32] ERROR[2605] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:03:34] ERROR[2212] app_rpt.c: Continual RPT thread restarts, killing Asterisk
[Sep 28 21:05:37] NOTICE[3433] cdr.c: CDR simple logging enabled.
[Sep 28 21:05:37] NOTICE[3433] loader.c: 53 modules will be loaded.
[Sep 28 21:05:37] WARNING[3433] chan_iax2.c: Unable to open IAX timing interface: No such file or directory
[Sep 28 21:05:37] WARNING[3433] acl.c: is not a valid IP
[Sep 28 21:05:37] ERROR[3433] codec_dahdi.c: Failed to open /dev/dahdi/transcode: No such file or directory
[Sep 28 21:05:37] NOTICE[3440] app_rpt.c: Normal Repeater Init 41715
[Sep 28 21:05:37] NOTICE[3440] app_rpt.c: Normal Repeater Init 41834
[Sep 28 21:05:37] WARNING[3457] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:37] ERROR[3457] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:05:37] WARNING[3458] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:37] ERROR[3458] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:05:38] WARNING[3440] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:05:38] WARNING[3440] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:05:38] WARNING[3460] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:38] ERROR[3460] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:05:38] WARNING[3459] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:38] ERROR[3459] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:05:40] NOTICE[3440] app_rpt.c: RPT thread restarted on 41715
[Sep 28 21:05:40] WARNING[3440] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:05:40] NOTICE[3440] app_rpt.c: RPT thread restarted on 41834
[Sep 28 21:05:40] WARNING[3440] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:05:40] WARNING[3464] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:40] ERROR[3464] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:05:40] WARNING[3465] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:40] ERROR[3465] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:05:42] NOTICE[3440] app_rpt.c: RPT thread restarted on 41715
[Sep 28 21:05:42] WARNING[3440] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:05:42] NOTICE[3440] app_rpt.c: RPT thread restarted on 41834
[Sep 28 21:05:42] WARNING[3440] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:05:42] WARNING[3467] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:42] ERROR[3467] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:05:42] WARNING[3466] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:42] ERROR[3466] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:05:44] NOTICE[3440] app_rpt.c: RPT thread restarted on 41715
[Sep 28 21:05:44] WARNING[3440] app_rpt.c: rpt_thread restarted on node 41715
[Sep 28 21:05:44] NOTICE[3440] app_rpt.c: RPT thread restarted on 41834
[Sep 28 21:05:44] WARNING[3440] app_rpt.c: rpt_thread restarted on node 41834
[Sep 28 21:05:44] WARNING[3468] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:44] ERROR[3468] chan_dahdi.c: Unable to dup channel: No such file or directory
[Sep 28 21:05:44] WARNING[3469] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file or directory
[Sep 28 21:05:44] ERROR[3469] chan_dahdi.c: Unable to dup channel: No such file or directory
On Mon, Sep 28, 2015 at 9:46 PM, Loren Tedford lorentedford@gmail.com wrote:
Having issues with the linode asterisk stuff i installed awhile back…
asterisk will not start when restarted or forced to start it just hangs no errors
here is what messages show
[Sep 28 21:05:44] WARNING[3468] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file o$
[Sep 28 21:05:44] WARNING[3469] chan_dahdi.c: Unable to open ‘/dev/dahdi/pseudo’: No such file o$
Loren Tedford (KC9ZHV)
Email: lorentedford@gmail.com
Main Line:1-631-686-8878 Option 1 for Loren.
Fax Line 1:1-618-551-2755
Fax Line 2:1-631-686-8892 (New Fax line)
Cell: 618-553-0806
http://www.lorentedford.com
http://www.kc9zhv.com
http://hub.kc9zhv.com
Cell: 618-553-0806
