Linking private network nodes to hub
We are working on building out a Broadband Hamnet in our area. I have placed both of my repeaters on the network and I built a hub to connect them too. The hub sits on the edge of the network touching both the internet and the boradband hamnet network.
I have seen multiple messages about linking private repeaters to a hub however there hasn’t been a specific conclusion.
I will say that I did like Doug’s Idea of having each individual node auto connect to the the hub. There is no formal documentation that I have been able to find to test this.
Mike AE4ML
“We must reject the idea that every time a law is broken, society is guilty rather than the law breaker.It is time to restore the American precept that each individual is accountable for his actions.” ~ Ronald Regan
Mike,
You probably won’t find anything formal that fits the description of exactly what you want to do. Here is how I do it:
In rpt.conf in the node section add -
startup_macro=*A999
The function code can be anything you want that is not in conflict with any other function. Using the A,B,C,D codes is a good way to do it as it is unlikely anyone would enter that code on the RF side.
and in the function section add -
A999=cmd,/etc/asterisk/local/reconnect_local
File reconnect_local in /etc/asterisk/local
#! /bin/bash
/usr/sbin/asterisk -rx “rpt fun yournode *73distantnode1”
sleep 1
/usr/sbin/asterisk -rx “rpt fun yournode *73distantnode2”
sleep 1
/usr/sbin/asterisk -rx “rpt fun yournode *73distantnode3”
and of course more could be added. The script has to be executable. The sleeps are probably not necessary but it certainly does not hurt anything putting them in. You could also do these multiple connects right within the function command in rpt.conf but I like to use external scripts. You also have the choice of running them via a cron job or manually from the command line.
As I mentioned before you also have the choice of inbound permanent connections to the hub which also work but in the opposite direction. Each remote site would have a startup macro that would connect to the hub. Doing it this way you could come in RF and enter the function code to connect to the hub if necessary.
There is no need to test it. It works. Permanent connections will reconnect if this is a link disruption or the distant station is restarted or rebooted but remember they go away when the originating system is restarted or rebooted. That is why you use a startup macro.
I don’t think it really makes much difference which way you do it inbound or outbound. Either way it depends on the hub being there. You could setup some redundancy with some more scripting if you were using inbound connections to the hub that in the event the hub was not there the remote nodes would create alternate connections.
73 Doug
WA3DSP
Date: Fri, 19 Dec 2014 12:18:30 -0500
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] Linking private network nodes to hub
Mike AE4ML
