As part of my setting up my nodes, I’ve got 2 Pi3s, each configured as a private node, at my home QTH and connected to my local AREDN router. So the same local nettwork, right?
But man, there is a good 1 to 1.5 seconds of latency between Pi’s
I don’t think there’s any kind of audio delay setting I missed so perhaps this is simply processing time issues for the Pi?
That is much longer than normal. I’d expect a ½ second at the most. I don’t know what is wrong but something is not right. One thought… are the nodes behind a NAT router? If so take a look at Two Servers Behind NAT Router - AllStarLink Wiki
As all traffic between them is on the LAN side of my AREDN router, I don’t think NAT is an issue.
Also, perhaps I didn’t use the correct terminology (sorry, I am new to Allstar). I have 2 Raspberry Pi 3s, each one runs Allstar and they are connected to each other as private nodes via that router. I am also using Repeater-Builder RIM Lites as the interface to my controller
As a test, could you connect in via iaxrpt and see if the latency shows as well.
Unplug the RIM. Reboot. Test
I have found some RIM’s have issues that cause the latency.
That was not exactly what I was looking for in a test.
I wanted to see if it had the same effect without the rim.
To test that, you need to make a connection with iaxrpt software without the rim connected and without any of the usb drivers loaded (that’s why the reboot after unplugging).
