Problem - some sudo instructions require charecters from my keyboard and when i press the right key ,Linux changes the character to something else,so my sudo command wont work. Any ideas .???
See if this post helps with that:
Sounds like your keymap is not quite correct. Changing the default keymap Varies a little bit depending upon your distro but perhaps someone here can help with that given some info on your install.
Eric
Sent using SMTP.
On May 28, 2020, at 1:13 PM, Colin Jones via AllStarLink Discussion Groups [email protected] wrote:
| oz123colin
May 28 |
