Kerchunk filter or equivalent of pulseback timer?
Date: 2009/09/16 Wed PM 02:53:23 PDT
To: APP_RPT_Users <app_rpt-users@qrvc.com>
Subject: Re: [App_rpt-users] Kerchunk filter or equivalent of
  pulseback timer?
Matt Beasant wrote:
> Hi Steve,
> Yes I'm fine with doing the manual code updates, so if I can find it in
> the usual place, I can install it and then try some different values for
> the rxondelay setting.
<-- Hi Steve / Matt; Have I missed the solution to this? - what is the
extent of the code changes required?
Thanks!
Ramesh.
App_rpt-users@qrvc.com
The code changes are going to be messy. That's why I suggested waiting for the release. The gist of it is that you are going to need chan_usbradio.c and everything in the xpmr directory as well.
Please understand that because this is a manual change you need to proceed at your own risk; none of this code has been regressed against older versions. I'm not in a position right now to give intensive help if something goes wrong.
Steve
WA6ZFT
<-- Ah right o' Steve; I'll wait for the official release then - especially since the issue is only on one system that (was) connecting to the hub!
Cheers,
Ramesh.
