Kenwood TKR-820
Hello All,
Does anyone have the wiring for the Kenwood TKR-820 to the URI?? If you also have the
setting/file for the USBRADIO/SIMPLEUSB, I would appreciate it.
73 de Angelo
Here is how I wired it up.
Michael KD5DFB
URI to TKR-x20.pdf (65.2 KB)
On Oct 26, 2017 10:56, “A” aglorioso62@gmail.com wrote:
Hello All,
73 de Angelo
usbradio.conf for Kenwood TKR-820 using descriminator audio:
[usbXXXXX]
hdwtype=0
duplex=1
rxboost=0
txboost=0
rxctcssrelax=1
ctcssfrom=no
carrierfrom=usbinvert
rxdemod=flat
rxsquelchdelay=100
txprelim=no
txlimonly=yes
txtoctype=no
txmixa=voice
txmixb=no
invertptt=0
rxondelay=1
rxnoisefiltype=0
eeprom=0
On Thu, Oct 26, 2017 at 12:03 PM, Michael Hebert mhebert1975@gmail.com wrote:
Michael KD5DFB
Hello All,
73 de Angelo
Paul / KN2R
Thanks Michael and Paul!!
You guys Rock.
Angelo
On 10/26/2017 11:10 AM, Paul Aidukas
[usbXXXXX]
hdwtype=0
duplex=1
rxboost=0
txboost=0
rxctcssrelax=1
ctcssfrom=no
rxdemod=flat
rxsquelchdelay=100
txprelim=no
txlimonly=yes
txtoctype=no
txmixa=voice
txmixb=no
invertptt=0
rxondelay=1
rxnoisefiltype=0
eeprom=0
Michael KD5DFB
                On Oct 26, 2017 10:56, "A"
<aglorioso62@gmail.com >
wrote:
                  Hello
All,
appreciate it.
                  73 de Angelo
                  [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
                  To unsubscribe from this list please visit [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
                  and scroll down to the bottom of the page. Enter
your email address and press the “Unsubscribe or
edit options button”
                  You do not need a password to unsubscribe, you can
do it via email confirmation. If you have trouble
unsubscribing, please send a message to the list
detailing the problem.
        and scroll down to the bottom of the page. Enter your email
address and press the “Unsubscribe or edit options button”
email confirmation. If you have trouble unsubscribing,
Paul / KN2R
Kenwood TKR-820: For descriminator audio use pin 4 instead of pin 10.
[usbXXXXX]
hdwtype=0
duplex=1
rxboost=0
txboost=0
rxctcssrelax=1
ctcssfrom=no
rxdemod=flat
rxsquelchdelay=100
txprelim=no
txlimonly=yes
txtoctype=no
txmixa=voice
txmixb=no
invertptt=0
rxondelay=1
rxnoisefiltype=0
eeprom=0
Michael KD5DFB
Paul / KN2R
Hello All,
73 de Angelo
Paul / KN2R
A friend and I both use the TKR-820s at home.
We discovered that his sounded "better" when he added a resistor L-
network, which consisted of a 4.7k and 470 ohm resistors, in the TX
audio path, from the URI to the LI of the repeater.
The TX audio out from the URI goes to the radio audio in has the 4.7k
resistor in series. The 470 ohm resistor, connects to the 'radio' side
of the 4.7k, and is connected to GND.
Something to consider adding to your URI -> radio's TX audio path if
you find that Allison sounds over deviated when you can barely hear
her.
You should not connect any wires to the audio GND, as they are floating
grounds.
You may find that you have to add a toroid, wrapped several times with
the TX and RX audio leads, to eliminate common mode, else stray RF
getting into the URI and TX audio input paths. When you hear someone
elses node, usually the portable RPi's with HTs, the buzz you hear, is
RF getting into the audio leads. Not a fun problem to fix as it does
take some testing to get the RF choke in the right spot.
When connecting the audio out from the URL into the repeater, I half-
witted solder the audio in wire to the MIC input of the repeater, and
hence not very good audio. I am going to fix that tonight!
~Benjamin, KB9LFZ
Michael KD5DFB
On Oct 26, 2017 10:56, "A" <aglorioso62@gmail.com> wrote:
> Hello All,
> 73 de Angelo
> App_rpt-users mailing list
> To unsubscribe from this list please visit http://lists.allstarlink
> .org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the
> You do not need a password to unsubscribe, you can do it via email
> confirmation. If you have trouble unsubscribing, please send a
To unsubscribe from this list please visit http://lists.allstarlink.o
