A couple years ago I hacked up randy’s scripts to get
the weather to work with allstar.
I am redoing them now that the NWS went with the CAP
protocol and zapped the RSS feed.
before I completely re-invent the wheel has anyone else done this.
Right now I am in grep sed hell . I am rewriting the scripts to
go grab the weather the new way the NWS wants you to. its a hell of a mess right now. go get a url, part out a url go get that parse out text
it’s mostly working for one alert, but if there are more than one it gets really complex parsing that out.
It does still get the current conditions and forecast still. sends it
to cepstral for TTS and save them as ulaw for asterisk to play.
If no one has done it can anyone chime in a help with the parsing.
there is a perl module to do this but my perl-fu is weak!
Don Russell, CBRE CBNT
W9DRR - ARRL OES, Technical Specialist
http://www.socialengineer.us
W0anm73
February 21, 2013, 2:18am
2
It supports wx alerts, wx forecast reports, and current weather underground reports.
Let me know if this interest you.
Look at
http://w0anm.com/blog
For more information. I have to tar up or package the scripts for Allstar.
73,
Chris, w0anm (irlp node 3106, Allstar node 29061)
W0anm73
February 25, 2013, 3:33pm
3
Hi Don,
I have been busy with work and had my allstar node system die. I am in the process of bringing up the node with new hardware.
There are quite a number of things to do regarding all the scripts. I have modified the scripts to include most of the functionality and cleaned up where the directories are pointed and also included a new log area for the weather script logs. I should get something together this week for the group here. I also want to put together some basic documents for the allstar port.
Glad you got it working, you may want to change over to the new port when I get this completed. Sorry for the delay.
Cheers,
Chris, w0anm (Pirlp node 3106, Allstar node 29106)
On Fri, Feb 22, 2013 at 5:12 PM, Don Russell w9drr.ham@gmail.com wrote:
Yeah, that’s the ones I was working with. I see your current set, and they are a lot different.
still doing things mostly the same way.
Do you have a tarball of them modified to work with allstar?
what I did was remove any the IRLP specific stuff from them.
profile, basically anything that mentioned irlp, and hard set some
of the paths instead of variables. made them run from /scripts/wx.
I had cepstral spit out .ul files and then sent an asterisk command
to play alerts, and then added in some dialplan options to play the rest.
I can probably re-engineer them like I did before, but if you already did
that’s great.
Look at
73,
