Currently new to Allstar and have a node setup. using 2x GM340’s, modified sound device. All working great but I would really like to have a K tone in-between overs on local RF. Can this be done?
Also I would like to set a Kerchunking setting on my repeater. Can this been done?
I am using HamVoip firmware 1.7.06 Allstar and Asterisk 1.4.23-pre.hanvoip-V1.7.1-04 app_rpt-0.327-01/22/2022.
Any help would be much apricated.
This is the min time as signal is present before it is acknowledged as a valid signal by the software.Each numuric value represents about 20ms of time.
So a value of 5 is 100ms.
It can be used to avoid light interference ‘pops’ and if you do not make it very high, it will not effect much as to normal operation.
If you make the number to high, likely you will be cutting off the beginning of normal speech.
Or, your users otherwise will have to be aware of it.
I saw the link for the Courtesy tone and have read it many times. Its not as easy it I though.
So what I am after is a the letter K in Morse to be active in between overs.
What is my the correct command line for this, is it the unlnkedct command? But what frequency do I need for the K? unlinkedct = ct2, ct2=|t(660,880,150,2048)
I believe one of the example CT’s is a cw k. I could be wrong.
You should try them all and see what is there
But be sure to set the right one for testing.
I would disconnect all links and use the first
Dont forget to restart after changes.
Found it, so changed unlinkedct=ct8 in courtesy tone mapping. Then went down to near the bottom and change in Telemetry courtesy tone definitions CT8 to ct8=|iK
