Connection issues between public / private node
Evening. I am running ASL3 on debian.
I used instructions at Easily Power Up Your AllStarLink3 with a DVSwitch Bridge – Michigan Radio Amateurs Technological Society to add a private node. These seem to line up with the instructions in manual.
have reviewed previous messages as well as working through manual and can't see what I have done wrong..
If I try and connect from Asterisk CLI this is what I get. Any of suggestions for where I should look? No other nodes connected so it should not be a case of having two "1999" private nodes (I will change this number).
Phil VK3VB
vk3vb*CLI> rpt cmd 67318 ilink 3 1999
-- Accepting UNAUTHENTICATED call from 127.0.0.1:4569:
-- > requested format = ulaw,
-- > requested prefs = (ulaw|adpcm|gsm),
-- > actual format = ulaw,
-- > host prefs = (ulaw|adpcm|gsm),
-- > priority = mine
-- Call accepted by 127.0.0.1:4569 (format ulaw)
-- Format for call is (ulaw)
[2026-05-11 10:00:57.071] WARNING[629379][C-00000021]: pbx.c:2942 pbx_extension_ helper: No application 'rpt,${NODE1}' for extension (radio-secure, 1999, 1)
== Spawn extension (radio-secure, 1999, 1) exited non-zero on 'IAX2/127.0.0.1: 4569-7544'
-- Hungup 'IAX2/127.0.0.1:4569-7544'
-- Hungup 'IAX2/127.0.0.1:4569-5999'
-- Hungup 'DAHDI/pseudo-1189574036'
