Ok all I'm back to work today and playing with this setup again.
I was able to isolate a much better signal for COR than what I had before.
This now truely goes from 0V->5V only when receiving and not when
transmitting. However I'm still having issues.
As soon as asterisk receives a signal it immediately tries to transmit a
signal out. This then effectively pulls the PTT low and my receiver stops
receiving. It is almost like it is in duplex mode but I have in
usbradio.conf
duplex=0 ; Full Duplex
rxondelay=0 ; Uncomment and/or adjust for simplex nodes to
eliminate "Ping Ponging"
; or "Relay Racing".
; A positive value here will instruct the usbradio
driver to ignore the
; COR line for a specified number of 20mSec
intervals following the
; release of PTT. Use this only on simplex nodes,
and leave commented
; out for repeaters or other full duplex nodes.
eeprom=1
Just for clarity I'll post my entire usbradio.conf below:
[general]
[usb]
hdwtype=0 ; Leave this set to 0 for USB sound fobs modified
using
rxboost=1 ; 0 = 20db attenuator inserted, 1= 20db attenuator
removed
; Set to 1 for additonal gain if using a low-level
receiver output
rxctcssrelax=1 ; reduce talkoff from radios w/o CTCSS Tx HPF
;txctcssdefault=100.0 ; default tx ctcss freq, any frequency permitted
;rxctcssfreqs=100.0 ; rx ctcss freqs in floating point. must be in table
;txctcssfreqs=100.0 ; tx ctcss freqs, any frequency permitted
rxctcssoverride=1 ; Set to 1 or yes to start out in carrier squelch
mode
carrierfrom=usb ; no,usb,usbinvert,dsp,vox
; usb - from the COR line on the modified USB sound
fob
; usbinvert - from the inverted COR line on the
modified USB sound fob
; dsp - from RX noise using dsp techniques
; vox - voice activated from RX audio
ctcssfrom=no ; no,usb,dsp
; no - CTCSS decoding, system will be carrier
squelch
; usb - CTCSS decoding using input from USB FOB
; (currently not supported)
; dsp - CTCSS decoding using RX audio in DSP.
; rxdemod option must be set to flat for this to
work.
rxdemod=speaker ; input type from radio: no,speaker,flat
; flat - Use RX audio from discriminator (before
de-emphasis)
txprelim=no ; Audio processing on left output channel: no,yes
; no - Audio is not pre-emphasized and limited.
; Suitable for use on a microphone input
; yes - Audio is pre-emphasized and limited.
; Suitable for direct connection to an FM modulator
txlimonly=no ; Audio limiting with no pre-emphasis on output
channel: no,yes
; no - Audio is not limited.
; yes - Audio is limited.
; Suitable for transmitters with no limiting but
with pre-emphasis.
txtoctype=no ; Transmit tone control type: no,phase,notone
; phase - encode CTCSS and reverse phase
; AKA ("reverse burst") before unkeying TX
; notone - encode CTCSS and stop sending tone before
unkeying TX
; AKA ("chicken burst")
txmixa=voice ; Left channel output: no,voice,tone,composite,auxvoice
; no - Do not output anything
; voice - output voice only
; tone - CTCSS tone only
; composite - voice and tone
; auxvoice - auxiliary voice output at headphone
level for monitoring
txmixb=no ; Right channel output: no,voice,tone,composite,
auxvoice
; See txmixa above.
invertptt=0 ; Invert PTT 0 = ground to transmit, 1 = open to
transmit
; This is the collector lead of the 2n4401 on the
modified
; usb sound fob.
; please refer to the howto for the procedure to do
this.
and leave commented
eeprom=1
Any thoughts on why asterisk would be trying to send a signal as soon as it
receives one? After the first time (upon asterisk restart) it receives a
signal it sends a beep followed by a morse code sequence.
Josh
-----Original Message-----
Sent: Thursday, July 04, 2013 8:48 AM
To: Joshua Hintze; [email protected]
Subject: RE: [App_rpt-users] Issue with Hangup after first keying
Are you running full duplex on a simplex radio?
Corey N3FE
________________________________________
On Behalf Of Joshua Hintze [[email protected]]
Sent: Wednesday, July 03, 2013 3:58 PM
To: [email protected]
Subject: [App_rpt-users] Issue with Hangup after first keying
Hello,
It is my first posting on here. I have ALMOST gotten the ACID installation
working. I'm using the URI interfaced to ACID and to my radio. The asterisk
can properly key the radio and its working just fine with that. I can also
connect to the node with iaxRpt directly with no problem and transmit OUT of
my radio.
However I am having some issues when my radio receives communication in that
as soon as I get my first radio RX, asterisk will then play a tone out of
the URI into the radio over and over again at about a one second interval.
In the asterisk terminal it just keeps repeating:
-- Hungup 'Zap/pseudo-1726358622'
-- Hungup 'Zap/pseudo-1774817359'
-- Hungup 'Zap/pseudo-691532115'
-- Hungup 'Zap/pseudo-81389311'
-- Hungup 'Zap/pseudo-465154784'
-- Hungup 'Zap/pseudo-627058532'
-- Hungup 'Zap/pseudo-1656870264'
-- Hungup 'Zap/pseudo-1671691803'
-- Hungup 'Zap/pseudo-50274194'
forever keeping my radio always keyed.
I have the COR from the radio going into the URI. I do not plan on using
CTCSS and have tried tying it to ground as well as tying it to the COR as
well. My usbradio.conf has the following:
carrierfrom=usb
ctcssfrom=no
I have tried also ctcssfrom=usb as well.
Josh
This message was scanned and is believed to be clean.
Click here to report this message as
spam.<http://simba.repeater.net:8080/cgi-bin/learn-msg.cgi?id=6EF48221A.A93B
