Issue installing update asl3
Has anyone experienced this.
utoinstall of module dahdi/3.4.0 for kernel 6.18.50+rpt-rpi-2712 (aarch64)
Building module(s)..........(bad exit status: 2)
Failed command:
(make modules KVERS=6.18.50+rpt-rpi-2712 MODULES_EXTRA='dahdi_dummy'; make KVERS=6.18.50+rpt-rpi-2712)
Error! Bad return status for module build on kernel: 6.18.50+rpt-rpi-2712 (aarch64)
Consult /var/lib/dkms/dahdi/3.4.0/build/make.log for more information.
Autoinstall on 6.18.50+rpt-rpi-2712 failed for module(s) dahdi(10).
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 1
dpkg: error processing package linux-headers-6.18.50+rpt-rpi-2712 (--configure):
installed linux-headers-6.18.50+rpt-rpi-2712 package post-installation script subprocess returned error exit status 1
Setting up linux-image-6.18.29+rpt-rpi-v8 (1:6.18.29-1+rpt1) ...
/etc/kernel/postinst.d/dkms:
The kernel is built without module signing facility, modules won't be signed
Autoinstall of module dahdi/3.4.0 for kernel 6.18.29+rpt-rpi-v8 (aarch64)
Building
dahdi modules are no longer need you can remove the package using apt remove.
Do an apt remove dahdi-dkms && apt autoremove. That will clear up this issue.
