Hello group,
I have two ASL 3 nodes on the same network and I am attempting to monitor both from my main node.
Here is the config I have setup in allmon3.ini.
[585243]
host=127.0.0.1
user=admin
pass=XXXXXXX
multinodes = 585243
[585246]
host=192.168.50.104
user=admin
pass=XXXXXXX
voter=y
votertitle=Megavoter
Node shows up on the dashboard page be not pulling and data.
I have port forwarding setup on 585243 and also set up in RPT.config.
585243 = radio@127.0.0.1:4566/585243,NONE
585246 = radio@192.168.50.104:4563/585246,NONE
Any help would be appreciate.
Dave/AD4UU
N8EI
August 27, 2024, 3:26pm
2
Please provide useful logging output from journalctl -xeu allmon3. However, some comments:
You don’t need multinodes for [585243]. That’s only telling Allmon3 there are multiple nodes on the same IP address.
Is node 585246 really running a voter or did you just copy/paste that?
Is 585246 running on 192.168.50.104 setup in /etc/asterisk/manager/conf to listen on 0.0.0.0/0 instead of 127.0.0.1?
This log is from 585253 were I am pulling from.
Aug 27 12:06:20 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - attempting reconnection retry #74
Aug 27 12:06:20 ASL-585243 allmon3[1175]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.50.104:5038: [Errno 113] Connect >
Aug 27 12:06:20 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - sleeping for RETRY_INTERVAL of 15
Aug 27 12:06:35 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - attempting reconnection retry #75
Aug 27 12:06:35 ASL-585243 allmon3[1175]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.50.104:5038: [Errno 113] Connect >
Aug 27 12:06:35 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - sleeping for RETRY_INTERVAL of 15
Aug 27 12:06:50 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - attempting reconnection retry #76
Aug 27 12:06:50 ASL-585243 allmon3[1175]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.50.104:5038: [Errno 113] Connect >
Aug 27 12:06:50 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - sleeping for RETRY_INTERVAL of 15
Aug 27 12:07:05 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - attempting reconnection retry #77
Aug 27 12:07:05 ASL-585243 allmon3[1175]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.50.104:5038: [Errno 113] Connect >
Aug 27 12:07:05 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - sleeping for RETRY_INTERVAL of 15
Aug 27 12:07:20 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - attempting reconnection retry #78
Aug 27 12:07:20 ASL-585243 allmon3[1175]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.50.104:5038: [Errno 113] Connect >
Aug 27 12:07:20 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - sleeping for RETRY_INTERVAL of 15
Aug 27 12:07:35 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - attempting reconnection retry #79
Aug 27 12:07:35 ASL-585243 allmon3[1175]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.50.104:5038: [Errno 113] Connect >
Aug 27 12:07:35 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - sleeping for RETRY_INTERVAL of 15
Aug 27 12:07:50 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - attempting reconnection retry #80
Aug 27 12:07:50 ASL-585243 allmon3[1175]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.50.104:5038: [Errno 113] Connect >
Aug 27 12:07:50 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - sleeping for RETRY_INTERVAL of 15
Aug 27 12:08:05 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - attempting reconnection retry #81
Aug 27 12:08:05 ASL-585243 allmon3[1175]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.50.104:5038: [Errno 113] Connect >
Aug 27 12:08:05 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - sleeping for RETRY_INTERVAL of 15
Aug 27 12:08:20 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - attempting reconnection retry #82
Aug 27 12:08:20 ASL-585243 allmon3[1175]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.50.104:5038: [Errno 113] Connect >
Aug 27 12:08:20 ASL-585243 allmon3[1175]: INFO: (asl_allmon.allmon3_ws_status) node: 585246 - sleeping for RETRY_INTERVAL of 15
lines 242-289/289 (END)
N8EI
August 27, 2024, 6:02pm
5
dmlad4uu:
585246
You have node 585246 configured incorrectly. It’s not accepting inbound AMI/manager connections.
N8EI:
Thanks for help. I haven't found it yet, but will keep looking.
k8upe
September 8, 2024, 3:51am
7
Just wonder if anyone ever figured this out. I am having the same issue. I have been on this for 10 days trying to figure it out. I have read about every single post on it and still nothing. If I change the ports to 5038 and 5039 I get this error WARNING: (asl_allmon.ami_conn) connection failed to 192.168.1.150:5039:5038: then the rest of the line. I have started over 3 times and get the same issue. Any Suggestions?
This is from journalctl -xeu allmon3.
Sep 07 23:35:20 hub152 allmon3[1330]: INFO: (asl_allmon.node_db) populated AllSt arlink database
Sep 07 23:36:13 hub152 allmon3[1330]: ERROR: (asl_allmon.ami_conn) asl_cmd_respo nse() Exception: <class ‘AttributeError’>
Sep 07 23:36:13 hub152 allmon3[1330]: ERROR: (asl_allmon.ami_conn) asl_cmd_respo nse() Message: ‘NoneType’ object has no attribute ‘write’
Sep 07 23:36:13 hub152 allmon3[1330]: WARNING: (asl_allmon.allmon3_ws_status) am i_conn socket problem for node 294150: unhandled error
Sep 07 23:36:13 hub152 allmon3[1330]: WARNING: (asl_allmon.ami_conn) ‘NoneType’ object has no attribute ‘write’
Sep 07 23:36:13 hub152 allmon3[1330]: WARNING: (asl_allmon.ami_conn) ‘NoneType’ object has no attribute ‘close’
Sep 07 23:36:13 hub152 allmon3[1330]: INFO: (asl_allmon.allmon3_ws_status) node: 294150 - sleeping for RETRY_INTERVAL of 15
Sep 07 23:36:28 hub152 allmon3[1330]: INFO: (asl_allmon.allmon3_ws_status) node: 294150 - attempting reconnection retry #1
Sep 07 23:36:28 hub152 allmon3[1330]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.1.150:5038: [Errno 113] Connect call failed (‘192.168.1.150’, 5038)
Sep 07 23:36:28 hub152 allmon3[1330]: INFO: (asl_allmon.allmon3_ws_status) node: 294150 - sleeping for RETRY_INTERVAL of 15
Sep 07 23:36:43 hub152 allmon3[1330]: INFO: (asl_allmon.allmon3_ws_status) node: 294150 - attempting reconnection retry #2
Sep 07 23:36:43 hub152 allmon3[1330]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.1.150:5038: [Errno 113] Connect call failed (‘192.168.1.150’, 5038)
Sep 07 23:36:43 hub152 allmon3[1330]: INFO: (asl_allmon.allmon3_ws_status) node: 294150 - sleeping for RETRY_INTERVAL of 15
Sep 07 23:36:58 hub152 allmon3[1330]: INFO: (asl_allmon.allmon3_ws_status) node: 294150 - attempting reconnection retry #3
Sep 07 23:37:18 hub152 allmon3[1330]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.1.150:5038: [Errno 113] Connect call failed (‘192.168.1.150’, 5038)
Sep 07 23:37:18 hub152 allmon3[1330]: INFO: (asl_allmon.allmon3_ws_status) node: 294150 - sleeping for RETRY_INTERVAL of 15
Sep 07 23:37:33 hub152 allmon3[1330]: INFO: (asl_allmon.allmon3_ws_status) node: 294150 - attempting reconnection retry #4
Sep 07 23:37:33 hub152 allmon3[1330]: WARNING: (asl_allmon.ami_conn) connection failed to 192.168.1.150:5038: [Errno 113] Connect call failed (‘192.168.1.150’, 5038)
manager.conf
[general]
enabled = yes
port = 5038
bindaddr = 0.0.0.0 ; Comment when not localhost access
[admin]
secret = 123456
read = all,system,call,log,verbose,command,agent,user,config
write = all,system,call,log,verbose,command,agent,user,config
;deny = 0.0.0.0/0.0.0.0 ; Uncomment when not localhost
;permit=1.2.3.4/255.255.255.255 ; Uncomment when not localhost
allmon3.ini
[294152]
host=127.0.0.1
user=admin
pass=123456
[294150]
host=192.168.1.150
user=admin
pass=123456
N8EI
September 8, 2024, 11:56am
8
Does the host 192.168.1.150 have a local firewall?
k8upe
September 8, 2024, 3:12pm
9
Not that I am aware of. Just some more info that may or may not help. I have 3 nodes, only worried about the 2. It works on its own, for example I can see 294150 and 294152 by itself. Just cant see the added node. It is all on the same LAN and is wired through a un-managed network switch.
k8upe
September 8, 2024, 3:29pm
10
Side note, as a test i completely disabled the firewall on 294150 and it all started to work as it should.
N8EI
September 8, 2024, 4:30pm
11
Glad you found the source of the issue.
k8upe
September 8, 2024, 5:47pm
12
Thank you for pointing that out. My router will do all my firewall stuff from here on out.
