Thanks Mike for your response.
The DMTF was sent by the radio. I watched the received codes on asterisk CLI. All received correctly.
rpt.conf… too much to post… just the top part… pls let me know if you need more
; Radio Repeater configuration file (for use with app_rpt)
; Your Repeater
; This is where you define your nodes which can be connected to.
[nodes]
49045 = radio@127.0.0.1:4569/49045,NONE ; This must be changed to your node number
; and iax port number if not the default
[49045] ; Change this to your assigned node number
; Must also be enabled in modules.conf
; Rx audio/signalling channel. Choose ONLY 1 per node stanza
; Enable the selected channel driver in modules.conf !!!
; rxchannel = dahdi/pseudo ; No radio (hub)
rxchannel = SimpleUSB/usb_49045 ; SimpleUSB
; rxchannel = Pi/1 ; Raspberry Pi PiTA
; rxchannel = Radio/usb_49045 ; USBRadio (DSP)
; rxchannel = Dahdi/1 ; PCI Quad card
; rxchannel = Beagle/1 ; BeagleBoard
; rxchannel = USRP/127.0.0.1:34001:32001; GNU Radio interface USRP
; rxchannel = Voter/49045 ; RTCM device
duplex = 1 ; 0 = Half duplex with no telemetry tones or hang time.
; 1 = Half duplex with telemetry tones and hang time. Does not repeat audio.
; This mode is preferred when interfacing a repeater.
linktolink = no ; disables forcing physical half-duplex operation of main repeater while
; still keeping half-duplex semantics (optional)
linkmongain = 0 ; Link Monitor Gain adjusts the audio level of monitored nodes when a signal from another node or the local receiver is received.
; If linkmongain is set to a negative number the monitored audio will decrease by the set amount in db.
; If linkmongain set to a positive number monitored audio will increase by the set amount in db.
; The value of linkmongain is in db. The default value is 0 db.
erxgain = -3 ; Echolink receive gain adjustment
; Note: Gain is in db-volts (20logVI/VO)
etxgain = 3 ; Echolink transmit gain adjustment
;eannmode = 1 ; 1 = Say only node number on echolink connects (default = 1)
; 2 = say phonetic call sign only on echolink connects
; 3 = say phonetic call sign and node number on echolink connects
- simpleusb.conf:
; If you are going to use this channel driver, you MUST enable it in modules.conf
; change:
; noload => chan_simpleusb.so ; CM1xx USB Cards with Radio Interface Channel Driver (No DSP)
; to:
; load => chan_simpleusb.so ; CM1xx USB Cards with Radio Interface Channel Driver (No DSP)
; SimpleUSB configuration
[general]
[usb_49045]
; 0 = no (default)
; 1 = yes
hdwtype = 0 ; Leave this set to 0 for USB sound fobs modified using
; Receiver parameters
rxboost = 0 ; 0 = 20db attenuator inserted, 1= 20db attenuator removed
; Set to 1 for additonal gain if using a low-level receiver output
carrierfrom = no ; no,usb,usbinvert
; usb - from the COR line on the USB sound fob (Active high)
; usbinvert - from the inverted COR line on the USB sound fob (Active low)
ctcssfrom = no ; no,usb,usbinvert
; usb - CTCSS decoding using input from USB sound fob (Active high)
; usbinvert - from the inverted CTCSS line on the USB sound fob (Active low)
deemphasis = no ; enable de-emphasis (input from discriminator)
plfilter = no ; enable PL filter
;rxondelay = 0 ; number of 20ms intervals to hold off receiver turn-on indication
; Transmitter parameters
txmixa = voice ; Left channel output (A): no,voice
; no - Do not output anything
; voice - output voice only
txmixb = no ; Right channel output (B): no,voice
txboost = 0
invertptt = 0 ; Invert PTT: 0,1
; 0 - ground to transmit
; 1 - open to transmit
preemphasis = 0 ; Perform standard 6db/octave pre-emphasis
; pager = no ; no,a,b (e.g. pager = b means “put the normal repeat audio on channel A, and the pager audio on channel B”)
; duplex3 = 0 ; duplex 3 gain setting (0 to disable)
duplex = 0 ; Duplex 0,1
; 0 - half duplex
; 1 - full duplex
#includeifexists custom/simpleusb.conf
BTW, the network that the raspberry PI currently located only allows outbound traffic. I read on the web that allowing inbound traffic is not necessary only if my node allows connection in.
Thanks, Kam
