As the title says, I am looking for an Echo Test For Allstar? Or a way to hear my own audio without annoying everyone on my local repeater.
Rob
Rob
There are several. I run one on node 55553.
Allstarlink.org hosts and official one on node 2002, which not only parrots your audio, but also does basic network diagnostics, I.E. will tell you if your node is unregistered, and if it is, if your Asterisk can be reached from the outside world. That same code is also running on node 61057.
IN the UK, there is node 40894.
In the midwestern United States, node 52171.
There are probably others.
I generally use 2002 most of the time these days.
Thank you very much, this helped a lot. I finely getting my audio levels correct.
