AB1PH
1
I would like to be able to look back over connections made to my AllStar node.
Is there a log file capturing this information?
I looked at /etc/asterisk/connectionlog but it does not appear to be capturing this information.
A first pass search for information on this did not turn up documentation but perhaps I had a poorly formed search.
Any assistance would be appreciated.
KK9ROB
2
Supermon includes this feature but needs to be properly setup to use it. The logfile is at /var/log/asterisk/connectlog
I think you’re using HamVoIP, so in order to use this, you must add these two lines under your node stanza in rpt.conf:
connpgm=/usr/local/sbin/supermon/smlogger 1 ; use this line for Supermon
discpgm=/usr/local/sbin/supermon/smlogger 0 ; use this line for Supermon
Then run rpt reload in Asterisk.
Cheers,
Rob
system
Closed
5
