We have since released the latest to dl.allstarlink.org. Please use the
ISO to download and install from dl.allstarlink.org. Your installation
attempting to get it's files from dltest.allstarlink.org which means the
iso you are currently using was obtained from there.
dltest.allstarlink.org is a test site and shouldn't be relied upon for
production systems.
If you are adventurous, you can try editing the file /etc/rc.d/acidrepo
and change the url inside of it to dl.allstarlink.org, but this may not
work if the test version you are running is very old.
Is there a different procedure for setting up irlp in app_rpt.c version 0.203?
./irlpsetup.sh
--14:07:24-- http://dltest.allstarlink.org/installcd/irlp-centos-install
Resolving dltest.allstarlink.org... 67.23.8.125
Connecting to dltest.allstarlink.org|67.23.8.125|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
14:07:24 ERROR 404: Not Found.
chmod: cannot access `irlp-centos-install': No such file or directory
./irlpsetup.sh: line 13: ./irlp-centos-install: No such file or directory
Thanks!
John
production systems.
Steve
WA6ZFT
OK, now you're really confusing this newbie... isn't the ACID app_rpt.c version 0.203 installed on CentOS 5.3?
The download link at dl.allstarlink.org indicates Centos 5.1
./irlpsetup.sh
Thanks!
John
production systems.
Steve
WA6ZFT
The contents of the ISO and CD remains the same regardless of which
version it is. During the update process, it will become Centos 5.3 with
app_rpt version 0.203. A lot packages and source code get downloaded
from the net after the CD boots. What is on the CD is just enough to get
the process started.
./irlpsetup.sh
Thanks!
John
production systems.
Steve
WA6ZFT
Steve
WA6ZFT
Thanks for the education. Makes perfect sense. BTW, your suggestion to edit /acidrepo worked. My test download was only about a week old.
The node appears on IRLP but apparently I still have some configuration to do. Doing my homework now before I ask more stupid questions...<g>.
