This is my first post, so pardon me if this has already been covered.
I wonder if there is any way to add native support for the IRLP board to app-rpt?
I’d like to avoid using CM108 Fobs in favor of my IRLP board. I already have a fan control circuit and remote transmitter shutoff via the AUX ports, plus I’d like to keep my hardware DTMF decoder.
If native support for the IRLP board isn’t possible, does anyone have any suggestions to get Echolink, IRLP and Asterisk working under TheLinkBox with my IRLP board?
My attempts so far to install the ACID CD, followed by IRLP software have been problematic. I’ve also tried the opposite with limited success.
Hello,
I'd like to avoid using CM108 Fobs in favor of my IRLP board. I already have a fan control circuit and remote transmitter shutoff via the AUX ports, plus I'd like to keep my hardware DTMF decoder.
If native support for the IRLP board isn't possible, does anyone have any suggestions to get Echolink, IRLP and Asterisk working under TheLinkBox with my IRLP board?
My attempts so far to install the ACID CD, followed by IRLP software have been problematic. I've also tried the opposite with limited success.
<-- Hi Kyle; I saw your post on the Asterisk Radio group as well.... I am not sure where you got the idea that rtpDir is discontinued.... it works quite well and for folks that want to use their IRLP board, it's probably your only choice.
I have setup rtpDir a few times now, as well as IRLP on top of an ACID install. Allstar node 2200 is a hub reflector where I use rtpDir to enable cross connectivity between Allstar, IRLP, and D Star - it works very well indeed!
If you need help - just ask... or connect to node 2200 or IRLP 0040 and give me a shout in the evening.
